Tip & How-To about Computers & Internet
Problem in turning on some applications program signal in laptop
Refer to the manual there are list of commands that will help you to activate your wirless signal...
make sure your router has turned on its wi-fi...
sometimes laptop has a quick button to on their wi-fi but some uses combination likes key "fn" + function key F1to F12
that's why you need to read the manual,..
hope its a help..
Computers & Internet Logo
i have a d link 615 and im trying to connect my dell precision M190 to it, but having problems even though it will connect to the network but Im unable to secure any internet
1. make sure your router is not near any cell phones, microwaves or TV's
2. Check your firewall settings
3. Make sure you have your router firmware updated.
4. connect your pc to the router physically this will let you know if your Ethernet card is working properly and you are getting signal from the ISP.
5. If you are connecting wirelessly then you have to make sure your router recognizes the PC's MAC (Media Access Control)
address.
To check to see if you have access and that the network see your PC
go to the command line and type ipconfig /all this will list all open network connection shown on the router.
this also can be done in the router.
6. Go into the router and check the status.
7. check the signal strength of the wireless it may not be connected.
8. Make sure your wireless adapter is active that is "enabled".
Apr 22, 2010 | Computers & Internet
can connect to DLINK adsl2 router via wirless but
Make sure your LAN connection is not disabled,
make sure that you are getting a valid IP address form the router
If you need commands for this let me know, also which OS are you using
Jan 31, 2010 | D-Link DI 514 Wireless Router (DI-514)
i HAVE a COMPAQ PESARIO CQ5O IT DOES CONNECT TO WIRLESS ROUTER WITH GOOD SIGNAL STRENGHT, BUT WHEN I TRY TO GET ON INTERNET IT SAYS IT CANT DISPLAY PAGE... Y.... IT WORKED THE FIRST DAY i GOT IT THEN IT STOP DISPLAYING WEB OR INTERNET
Hello Sir
Are you sure you are reconnecting to the wireless router or not? If so please go to the wireless connection wizard and search again for the wifi connection and make sure that you are actually connecting to the wireless network.
You can also reset the wireless router from the reset button that is on the router itself (refer to manual for the location of the reset button) and try and to the above again.
I hope that this solution was of help to you :)
Cheers
Jan 07, 2009 | HP Compaq nx9600 Notebook
low to no signal strength
Try agusting the wirless properties for your wirless card. You will need to go uder start then go to conect to and the show all conecsions. The you will need to right clcik on the wirless conecsion and go to properties. Now you will click the button that says configure. I hope this helps
Jan 01, 2009 | 2wire HomePortal 1800HG Router...
a 2nd pc connected to my belkin 54g wirless rouer now mine cannot
Of course you've clicked "refresh" wireless network list? Go to the working computer and in a DOS box type IPCONFIG /ALL to find the gateway address for the router. ( Or refer to your wireless connection utility ). I will probably be 192.168.0.1 for example. In your browser address line put HTTP://192.168.0.1 and click the arrow. You should be talking to the router now, default id and/or password is typically ADMIN. Go to wireless settings and make sure SSID broadcast is turned on. Also note the SSID name, encryption type ( WEP, WPA, etc ) and note the key, if any. You now have enough information to connect the second computer. Yeah, this is complicated. If it's more than you want to know best get a friend to help you, though I may be able to answer specific questions once you get into it.
Dec 27, 2008 | Belkin (F5D7230-4) Router (587009)
156 people viewed this tip
David Payne
David Payne
