Tip & How-To about Computers & Internet
How to find the power button inside the motherboard...
Inside the motherboard there are groups of pins that are in 2 pairs...
they are in 2 column...
you can noticed to them that the other one has a excess pin..
it means that is the group of pw button reset button pw led hdd led..
the other groups are for usb and internal speaker...
use a philips or screw driver, or even a long nose try to short the pins in pair if you already find the pins of the power button..the sequence of the next buttons are:
pw button
reset button
pw led
hdd led
that's all hope its a help..
Computers & Internet Logo
woule like the pin location for power & leds on F-P1 socket
The corner of the motherboard "diagonally-opposite" of the keyboard/mouse PS/2-port connectors has a grid of gold pins. One pair of pins is labelled 'PWR'.
One pair of pins is labelled 'RST SW' ("Reset Switch").
Another pair of pins is labelled 'PWR LED'.
Another pair of pins is labelled 'HDD LED'.
Jan 10, 2011 | Computers & Internet
where to plug led swich on motherboard ms-7103
There usually is a group of gold-coloured pins, diagonally opposite from the corner where the keyboard/mouse connectors are,
arranged in a "two-by-many" rectangle of rows and columns.
Look for either a "HD LED" or "PWR LED" label.
Connect the LED leads to connect one pin from the "top" row to one pin on the "bottom" row.
Apr 10, 2010 | Computers & Internet
had to replace power switch on emachine computer need to know where wires go
You must check cable(small) one the (left or right) one hard drive, CD Drive, floppy disk and for motherboard (the big one) .You check the manuals, is not hard just follow where the power lines.
Feb 21, 2010 | E-Machines eMachines T3830 PC Desktop
wiring of Ethernet cat6 cable for computer to the modem asm32 to excess to internet
Pinout is as follows:
http://www.mae.ufl.edu/sysinfo/cat6_cables.htm
Looking at the Cat6 connector with the lock tab facing up, look at the pins, (brass colored contacts) going from left to right.
From the left it's pins 1,2,3,4,5,6,7, and 8.
The wires are twisted together in pairs.
First pair
1.Pin 4 goes to the White wire with Blue bands.
2.Pin 5 goes to Blue wire.
Second pair
1.Pin 1 goes to the White wire with Orange bands.
2.Pin 2 goes to the Orange wire.
Third pair
1.Pin 3 goes to the White wire with Green bands.
2.Pin 6 goes to the Green wire.
Fourth pair
1.Pin 7 goes to the White wire with Brown bands.
2.Pin 8 goes to the Brown wire.
Apr 15, 2009 | Avaya Computers & Internet
Havimg prob with the 2 usb ports located in front
Hi manky, Normally front USB ports have a pair of 4 wire cable with connectors marked red wire is vcc; white wire is -D; green wire is +D; and black wire is gnd. The motherboard would normally have two pairs of dual pin connectors that would be sitting side by side or in-line with uneven pins - 4 and 5 pins; then another 4 and 5 pins. Please refer to the attached simple diagram for your connection. For some reason I couldn't get hold of a manual from the Gigabyte site of your particular model GA-81KHXT. Nonetheless hopes this works for you. Pls post again how things turn up. Good luck and kind regards.
Jun 01, 2007 | Intel Motherboard
163 people viewed this tip
David Payne
David Payne
