Tip & How-To about Computers & Internet
Trick and helpful tip for how you install a driver or application from cd that always fails
If you are experiencing some problems regarding to your cd drive....
when you are installing something it hang's up...
you can try to copy the file you want to install and save it in your computer..
here are the steps..
first put the cd in your cd drive..
if it autorun's just ignore it or better to close it.. then go to your cd drive icon in your my computer, right click the icon, click explore.
inside the cd highlight all the contents...
then right click choose copy..
go to where you want to paste the file ex. drive c: or d:
then create a folder then paste it inside..
then find the set up of the program,double click it then it will prompt you as it will prompt you when you are installing...
just do whar you are doing in installing...it will surely installed
but note if you copy the file from cd and there is a file you cant copy or there is an error, it means your cd is corrupted and you need to have another installer...
hope i give another help...rate this..
Computers & Internet Logo
My hp pavillion dvd drive just hangs up when I try to reinstall windows
Is the disk your using homemade or a factory made disk? Some drives just won't read 100% of the disks inserted into them. Have you tried another installation disk to see if the problem persisits? Are you able to "SEE" the files on the disk using Windows Explorer? Can you copy those files to your hard drive? If yes, then try installing from the hard drive files instead of the disk. What OS are you trying to install?
Apr 08, 2014 | Pioneer DVR-107D DVD±RW Burner
system file corrupt and CD Drive doesn't work to run Install CD
First: Boot into safe mode on "bad" laptop...
Open a command window...
(start, run, "cmd.exe", <enter>)
At the command prompt, type:
"CHKDSK /F"
It will probably say something about cannot lock the volume, do you want me to schedule a disk check at next startup? Say yes and reboot...
2nd:
Does the other laptop work, and does it have a functioning CD drive?
Yes?
Copy the I386 directory of the XP install CD to the USB Hard Drive using the working laptop.
Then, boot "bad" laptop into safe mode.
Plug USB HDD into "bad lapttop", hope it is recognized and copy the I386 directory to the c:\ drive.
After the copy is complete, run
C:\i386\WINNT32.EXE
Choose upgrade if you wish, but I'd have the program replace the existing windows installation. Leave the HDD as is if asked, do NOT format it. This way, you can navigate around and find your "old" data on the HDD after Windows has finished installing.
Have your installation Key/Serial No. at the ready.
Mar 09, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Windows installation issues
Either you have a defective CD, or a defective Hard Drive, or defective memory. Firstly is this a clean install? Try reformatting the drive and running chkdsk or a manufacturers disk utility. Then remove fingerprints and other marks from CD by wiping from the centre outwards. Let me know how you get on.
Apr 27, 2008 | HP Compaq dx2000 Microtower PC Desktop
acer aspire 5102 with philips sdvd8821 dvdram drive
alright. bubul78, your post is in no way shape or form a solution for the problems given by other users. I too have a acer laptop with the philips dvd drive in it, device manager detects the dvd reader and says it is running with no problems. i can hear the drive read the cd when inserted, tho when trying to access the drive through my computer the window hangs at the hourglass for a min or so, then says please insert a cd. only solution is that something is physically wrong with the drive. ok so solution found, replace the cd drive. but where is acers sight to order replacement parts? poor site navigation in my opinion.
Nov 01, 2007 | Acer (KV.16X04.007) DVD Drive
having problem installing office 2007 on Microsoft office Vista
Hi Noglao, I have experienced similar problem with my Office 2007 installation, I believe its a problem with the CD itself, there might be a scratch or something that is blocking this file from being read. Maybe even a manufacture error since I had the exact same problem with the same file. In the end I had to copy the disk to my hard drive and I moved it to a share folder on my file server. I mapped this share folder to a root(z:) on my workstation. I ran it from there and it worked just fine. If you don't have a server or can't map a folder for some reason I suggest trying another installation CD, or copy the files to your computer, burn a new CD and try it again with that CD. Good luck Daniel
Aug 16, 2007 | Microsoft Office Standard for PC
132 people viewed this tip
David Payne
David Payne
