Tip & How-To about Mozilla Firefox
Firefox Tricks!
Everybody’s favorite open-source browser, Firefox, is great right out of the box. And by adding some of the awesome extensions available out there, the browser just gets better and better.
But look under the hood, and there are a bunch of hidden (and some not-so-secret) tips and tricks available that will crank Firefox up and pimp your browser. Make it faster, cooler, more efficient. Get to be a Jedi master with the following cool Firefox tricks.
1) More screen space. Make your icons small. Go to View – Toolbar – Customize and check the “Use small icons” box.
2) Smart keywords. If there’s a search you use a lot (let’s say IMDB.com’s people search), this is an awesome tool that not many people use. Right-click on the search box, select “Add a Keyword for this search”, give the keyword a name and an easy-to-type and easy-to-remember shortcut name (let’s say “actor”) and save it. Now, when you want to do an actor search, go to Firefox’s address bar, type “actor” and the name of the actor and press return. Instant search! You can do this with any search box.
3) Keyboard shortcuts. This is where you become a real Jedi. It just takes a little while to learn these, but once you do, your browsing will be super fast. Here are some of the most common (and my personal favs):
  • Space bar (page down)
  • Shift-Space bar (page up)
  • Ctrl+F (find)
  • Alt-N (find next)
  • Ctrl+D (bookmark page)
  • Ctrl+T (new tab)
  • Ctrl+K (go to search box)
  • Ctrl+L (go to address bar)
  • Ctrl+= (increase text size)
  • Ctrl+- (decrease text size)
  • Ctrl-W (close tab)
  • F5 (reload)
  • Alt-Home (go to home page)
4) Auto-complete. This is another keyboard shortcut, but it’s not commonly known and very useful. Go to the address bar (Control-L) and type the name of the site without the “www” or the “.com”. Let’s say “google”. Then press Control-Enter, and it will automatically fill in the “www” and the “.com” and take you there – like magic! For .net addresses, press Shift-Enter, and for .org addresses, press Control-Shift-Enter.
5) Tab navigation. Instead of using the mouse to select different tabs that you have open, use the keyboard. Here are the shortcuts:
  • Ctrl+Tab (rotate forward among tabs)
  • Ctrl+Shft+Tab (rotate to the previous tab)
  • Ctrl+1-9 (choose a number to jump to a specific tab)
6) Mouse shortcuts. Sometimes you’re already using your mouse and it’s easier to use a mouse shortcut than to go back to the keyboard. Master these cool ones:
  • Middle click on link (opens in new tab)
  • Shift-scroll down (previous page)
  • Shift-scroll up (next page)
  • Ctrl-scroll up (decrease text size)
  • Ctrl-scroll down (increase text size)
  • Middle click on a tab (closes tab)
7) Delete items from address bar history. Firefox’s ability to automatically show previous URLs you’ve visited, as you type, in the address bar’s drop-down history menu is very cool. But sometimes you just don’t want those URLs to show up (I won’t ask why). Go to the address bar (Ctrl-L), start typing an address, and the drop-down menu will appear with the URLs of pages you’ve visited with those letters in them. Use the down-arrow to go down to an address you want to delete, and press the Delete key to make it disappear.
8) User chrome. If you really want to trick out your Firefox, you’ll want to create a UserChrome.css file and customize your browser. It’s a bit complicated to get into here, but check out this tutorial.
9) Create a user.js file. Another way to customize Firefox, creating a user.js file can really speed up your browsing. You’ll need to create a text file named user.js in your profile folder (see this to find out where the profile folder is) and see this example user.js file that you can modify. Created by techlifeweb.com, this example explains some of the things you can do in its comments.
10) about:config. The true power user’s tool, about.config isn’t something to mess with if you don’t know what a setting does. You can get to the main configuration screen by putting about:config in the browser’s address bar. See Mozillazine’s about:config tips and screenshots.
11) Add a keyword for a bookmark
. Go to your bookmarks much faster by giving them keywords. Right-click the bookmark and then select Properties. Put a short keyword in the keyword field, save it, and now you can type that keyword in the address bar and it will go to that bookmark.
12) Speed up Firefox. If you have a broadband connection (and most of us do), you can use pipelining to speed up your page loads. This allows Firefox to load multiple things on a page at once, instead of one at a time (by default, it’s optimized for dialup connections). Here’s how:
  • Type “about:config” into the address bar and hit return. Type “network.http” in the filter field, and change the following settings (double-click on them to change them):
  • Set “network.http.pipelining” to “true”
  • Set “network.http.proxy.pipelining” to “true”
  • Set “network.http.pipelining.maxrequests” to a number like 30. This will allow it to make 30 requests at once.
  • Also, right-click anywhere and select New-> Integer. Name it “nglayout.initialpaint.delay” and set its value to “0′. This value is the amount of time the browser waits before it acts on information it receives.
13) Limit RAM usage. If Firefox takes up too much memory on your computer, you can limit the amount of RAM it is allowed to us. Again, go to about:config, filter “browser.cache” and select “browser.cache.disk.capacity”. It’s set to 50000, but you can lower it, depending on how much memory you have. Try 15000 if you have between 512MB and 1GB ram.
14) Reduce RAM usage further for when Firefox is minimized. This setting will move Firefox to your hard drive when you minimize it, taking up much less memory. And there is no noticeable difference in speed when you restore Firefox, so it’s definitely worth a go. Again, go to about:config, right-click anywhere and select New-> Boolean. Name it “config.trim_on_minimize” and set it to TRUE. You have to restart Firefox for these settings to take effect.
15) Move or remove the close tab button. Do you accidentally click on the close button of Firefox’s tabs? You can move them or remove them, again through about:config. Edit the preference for “browser.tabs.closeButtons”. Here are the meanings of each value:
  • 0: Display a close button on the active tab only
  • 1:(Default) Display close buttons on all tabs
  • 2:Don’t display any close buttons
  • 3:Display a single close button at the end of the tab bar (Firefox 1.x behavior)
Mozilla Firefox Logo
how do I delete from my favorites
The following document contains information on how to manage your bookmarks and favorites in all of the major Internet browsers. To proceed, select your browser from the list below and follow the instructions.
- Internet Explorer
- Google Chrome
- Mozilla Firefox
- Opera
Internet Explorer
To access favorites:
Press Alt + C
or
Open Microsoft Internet Explorer.
Click on the Favorites IE favorites icon in the upper right-hand corner of the browser window.
Click any Favorite folder to expand and show its contents.
To delete favorites or folders:
- Right-click the favorite or folder you want to delete.
- Select Delete from the drop-down menu that appears.
To move and organize items in your favorites:
- Drag-and-drop your favorites or folders to rearrange them.
Renaming items in your favorites:
- Right-click the favorite or folder you want to rename.
- Select Rename from the drop-down menu that appears.
- Type in the desired name and press Enter.
Google Chrome
To access your bookmarks:
Press Ctrl + Shift + O
or
Open the Google Chrome Internet browser.
Click Customize and control google chrome Chrome settings in the upper right-hand corner of the browser window.
Move you mouse cursor over Bookmarks and then click Bookmark manager.
Deleting:
- Highlight the bookmark or folder you want to delete by clicking it once.
- Press the delete key on your keyboard to remove the bookmark or folder.
- Tip: You can also right-click a bookmark or folder, then select Delete from the menu.
Organizing:
- Drag-and-drop your bookmarks or folders to re-organize them.
Renaming:
- Right-click the bookmark or folder you want to rename.
- Select Edit... from the drop-down menu that appears.
Mozilla Firefox
Press Ctrl + Shift + B
or
Open the Mozilla Firefox Internet browser.
Click Show your bookmarks Firefox bookmarks in the upper right-hand corner of the browser window.
Select Show All Bookmarks.
Deleting:
Organizing:
Renaming:
- Highlight the bookmark or folder you want to rename by clicking it once.
- Locate the field labeled Name: in the lower right-hand section of the Library window.
Opera
or
Open the Opera Internet browser.
Click Customize and control Opera opera button in the upper left-hand corner of the browser window.
Select Bookmarks from the drop-down menu that appears.
Deleting:
- Locate the folder or bookmark you would like to delete and move your mouse cursor over it.
- A circled X should appear in the upper right-hand corner; click it to delete.
Organizing:
Renaming:
Apr 08, 2017 | GPS
How can I remove Malicious Add On from my computer
Download "Should I Remove It?" . It's free and deletes advertising.
Purge Your PC of Program Clutter
What is Should I Remove It? Should I Remove It? is a very simple but extremely powerful Windows application that helps users, both technical and non technical, decide what programs they should remove from their PC. This typically includes finding and removing all sorts of crapware and bloatware such as adware, spyware, toolbars, bundled unwanted applications as well as many forms of malware. The program is very lightweight and extremely fast. Should I Remove It? simply scans your computer for all its' installed programs and then ranks what should be removed by leveraging the wisdom of the crowd (and of course our technical experts) to determine what should not be installed.
Mar 08, 2015 | Microsoft Windows 7 Home Premium 64BIT...
why are there so many ads on this page
Install ABP (add block plus). Its an extension or app for your browser. Otherwise all sites have so much advertisement its terrible. With ABP they are all gone. I use Chrome and Firefox and both have ABP available free. If you use another browser just search add- on's and there will be a few available. I think ABP works best. I havent seen any ads in years.
Apr 14, 2014 | Netflix
I keep getting the error The connection to the server was reset while the page was loading with mozilla firefox. I have cleared my cache, history and followed other troubleshooting suggestions including. Please tell me how to fix this so i can access the site.
Hello pthaoasi, If you continue to get this error. Please try the following solutions. Uninstall Firefox and reinstall it. Uninstall Firefox and Install Google Chrome. (Google Chrome is a Great Web Browser) I hope these solutions help you :) Google Chrome is an awesome web browser which already has Adobe Flash player and other materials installed just in the one browser, the browser is not very big. I'm sure that Google Chrome should do the Job for you :)
- Steven ASAP
Here to help!
Apr 24, 2011 | Mozilla Firefox
201 people viewed this tip
Top Mozilla Computers & Internet Experts
Lesley Cameron
Lesley Cameron
k24674
Are you a Mozilla Computer and Internet Expert? Answer questions, earn points and help others
