Tip & How-To about Cell Phones
What is a Virgin Mobile Password Skip? How to turn it off/on?
The "Password Skip" feature lets get into your voicemail without entering your voicemail password. This feature only works when you call into your voicemail from your Virgin Mobile phone.
Here's how you can set up Password Skip for your Virgin Mobile Voicemail:
1. From the main menu, please press 3 for personal options.
2. Then press 3 for mailbox setting.
3. Then lastly, please press 2 to turn password skip on or off.
It is best to have password skip so that you won't have any problem even if you forgot your password.
Hope this tip helps! Please don't forget to rate! Have a great day!!!
Cell Phones Logo
on the samsung cellphone how to enter password to access voicmail
try using the last four digits of your phone number.
Mar 16, 2014 | straighttalk.com
Need to reset my voicemail password without original password
To reset password on any tel set go to main set and press feature 983 this gets you in to programming you need a password and default password is normly
120000 for 2 digit locals and 1020000 for 3 digit locals etc.enter this password and press ok go in to
mbox type in mailbox press change , press reset password. hope this works
Sep 17, 2009 | NorStar T7208 Corded Phone
T7316E Voicemail Password Issues
Feature 983
password is: 1020000 (if you use 3 difit extensions)
OR
120000 (if you have 2 digit extensions)
Jul 09, 2009 | Nortel T7316E 2-Line Corded Phone
Voicemail Lockout
Press the feature button then 983 enter 120000 as your password, if that doesn't work try a combination of 1020000, 10020000, etc... Enter the mailbox ext (The phone ext) hit reset and the password will be reset to 0000. You will be forced to change the password after you log into your mailbox again.
May 27, 2008 | NorStar T7316E Corded Phone
resetting company voicemail
Norstar Common Voicemail Features To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
took this from a guide i have, might help you guys out
Jan 07, 2008 | NorStar M7310 Corded Phone
742 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
