Tip & How-To about Cell Phones
How to reset your Virgin Mobile voicemail
Hi Virgin Mobile Users! Since your password is private, Virgin Mobile don't have any record of it. Don't worry you can still reset your mailbox, you can recover your password by doing the following steps below:
  1. Please press and hold the 1 button on your mobile.
  2. Then choose one of the following options.
    • If you have "password skip" turned off, you'll be asked for your password. Call customer care at 1.888.999.2321 from your mobile to reset your mailbox.
    • If you've got "password skip" turned on, press 3 for personal options.
  1. Press 3 for mailbox settings.
  2. Press 4 to change your password.
  3. Choose one of the following options.
  • Enter a new password (4 - 10 digits long, numbers only) then press #.
  • Press 0 to find out what your current password is. Then press * to keep it
Although, with the password reset, all your previous voice mails will be deleted and will no longer be retrievable. Hope this helps.... please don't forget to rate! thanks!!!
Cell Phones Logo
forgot login password for fujitsu lifebook v1010
Lost Windows password:
  • Log in as Administrator (try safe mode if you don't see Administrator).
  • Login as other user (if other user is availible) and manage users.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Aug 30, 2012 | Fujitsu Siemens LifeBook Computers &...
We have a KX-T7630 phone and we are trying to reset mailbox password but it won't work. We tried to delete password by accesing mailbox 999. We went to Other features Mailbox Setup . Reset Pas
You need to set a specific password. Probably in RESET password, it's reset to a default value, so if you don't know what the default is, then you can't use it. We usually use x(plus your extension), where x is like a digit 3 or 4, but I didn't install yours :-)
Carl
Aug 02, 2012 | Panasonic KX-T7630 Corded Phone
I can't get passed primary greeting recording.
Hi there Moodymar,
One thing you can try is logging into your mailbox as you would calling into your vmail system externally.....dial access phone number....here prompt.....dial ** mailbox number, then password. ""Sometimes"" this tricks it and you can get in. Question, does any one else have the same problem? If no, then unfortunately you have to get the system administrator to delete your mailbox and re-create it, you will loose msg's.
The nortel vmail systems are not forgiving if something doesn't sit right with them.
You also mentioned that mbox is full, do you here the system announce that?
Also make sure your mbox has not been set as a ""Information mailbox", maybe a silly question, just something to clear out of the way (this type of box does not record greetings).
Another thing, typically when mboxes are created on Norstar vmail systems the extension and mbox numbers match. Make sure you ext and mbox number match, cause 99.9 % of time they will. That small percentage of time they don't cause's confusion for the end users.
I know this is a lot of stuff, but, one last thing, to make sure your phone is operating okay, have someone else try logging into thier own vmail on your phone, or a couple of people
Jan 17, 2012 | NorStar T7316E Corded Phone
How can I check the voicemail, my assistant left and I don't know how to retrieve?
Where did your assistant check the voicemail? In a TVA system, each extension VM password can be reset from mailbox 999. If you don't have that password, you would have to call your dealer/installer or check their notes. If you're trying to get to the General Delivery Mailbox, it's done from the Message Manager's mailbox (998). Again, it needs notes, but I think you can reset that password from MB 999.
Carl
Aug 13, 2011 | Panasonic KX-T7633 Corded Phone
forgot my virgin mobile voicemail password. how do i reset it
Hi! Since your password is private, Virgin Mobile don't have any record of it. Don't worry you can still reset your mailbox, you can recover your password by doing the following steps below:
Jan 29, 2010 | LG RUMOR Cellular Phone
1,755 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
