Tip & How-To about Kitchen Appliances - Others
Garbage Disposal Smells
What can you do if your garbage disposal starts to stink up the kitchen? Because of the stuff that you put down the disposal and grind up the residue can sometimes start to create a foul odor that can be noticed in and around your kitchen. To combat this problem there are some general things that you can do and also some things that you and grind up in the disposal that will help to keep it smelling great.
One of the things that will make the disposal smell bad is if your dishwasher discharges through the garbage disposal. The food left after the water goes through will soon start to spoil and stink. Make sure that you run your disposal after the dishwasher runs to clean out the food and keep the disposal clean.
Some soft foods like meats and cooked vegetables will also tend to stick to the plate of the garbage disposal. These will cause a smell to develop after a time as they breakdown. To stop this from happening keep harder foods or foods that smell better for last to run down the disposal. This will help to clean the plate and keep the garbage disposal smelling better.
If you are going to be away for a long time, or you are having friends over and want your garbage disposal to smell good, you can use a lemon or lemons rinds. Cut up the lemon and grinds it up before you shut down the disposal. This will have your garbage disposal smelling great!!
There are also commercially produced garbage disposal cleaners, deodorizers, and degreasers, that you and buy at most grocery or hardware stores that are made specifically for this purpose.
http://www.fixya.com/support/r4062599-garbage_disposal_clogged_or_jammed
http://www.fixya.com/support/r4062792-best_way_use_garbage_disposal
Kitchen Appliances - Others Logo
my garbage disposal is not working. it "hums", but doesn't grind, and water drains slowly. there is nothing stuck in it.
You are going to have to try to push it through the stuck point. It is clogged without a doubt. Could be a piece of silverware in there. Use a flashlight and take a look down in the hole. Do not stick your hand in there but you can use a pliers or something to dislodge it.
May 16, 2016 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
why does kitchen sink drain water from drain side to garbage disposal side
The two drains are connected, but below the disposal. Likely if it's not draining down, you still have a clog, and the person the "cleared" the drain didn't.
Sep 03, 2014 | Garbage Disposals
water leaking from my kitchen aid garbage disposal
Disposal must be replaced. It has rusted out:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#install
Add a comment and say what you discover
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 05, 2013 | KitchenAid Kitchen Aid - KCDB250G Food...
1,248 people viewed this tip
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
