Tip & How-To about JVC HD-56G886 56" Rear Projection HDTV
To Clear Green Screen Problem
Here are the proceedures for taking care of this problem:
1) Turn on TV
2) Make sure the remote toggle switches are set to "TV" and "VCR" respectively
3) Press the "Sleep" button
4) Simultaneously press "Display" and "Video Status"
5) Press "2" (Self Check)
6) Turn off the TV
7) Wait for fan to turn off (30 seconds or so)
8) Unplug TV
9) Wait for 30 seconds
10) Turn TV back on
Hope this helps
JVC HD-56G886 56" Rear Projection HDTV Logo
cannnot hear the music from video
you have not stated whether you want to hear the sound on TV or Stereo Receiver..
Here are 2 possible solution for both alternative..
1. thru TV
Your VCR has either 2x Audio (red and whitw ) and 1x Video output (yellow) RCA jacks or a SCART jack on the back side..
you need to connect all 3xRCA jacks to your TV's respective input.(or SCART ) than you will manage to see both video and hear the sound by selecting the VIDEO input on the TV .
2.thru RECEIVER
** you need to connect "Audio Output " RCA jacks of your VCR
** to "AUX input " or "DVD " OR "Any input" of your receiver ( except Phone )
** than just switch to respective mode on
RECEIVER corresponding your RCA connection...
There you go..VCR sound on the
Receiver..
*** pls remember you can connect VCR to either TV or Receiver to listen audio ,not both..the yellow RCA video output connection always goes to TV..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us to continue f
or Helping out the Community :)
Jul 07, 2011 | Audio Players & Recorders
remote won't communicate with television
The sensor for these Panasonic tvs along with certain Toshiba models tend to have the problem with the sets sensor going out. But if you are using a universal remote because you do not have the original, then most likely you will need to use the vcr control codes to program the tv. but if the original doesnt work either. your insticts are probably right. There is one last trick if you do have the original remote that u can try. I've had this work for me several times on service calls. With the batteries removed. Press every single button on the remote once. make sure you do this nice and slow making sure you are pressing the button down . if its a toggle button or rocker button like most volume or channel up down buttons(meanning that physically the is one button but depending on what part of button you press it does something differemt) well treat these as seperate buttons. Also if the remote has any switches on it. Like vcr/tv switch or vcr 1 vcr 2 etc. Then switch to other position and repeat the process of pressing all buttons once again. (remote does not have too be pointed at tv for obvious reasons) Now replace the batteries and have fingers crossed. Good luck.
Mar 11, 2009 | Panasonic AG-520G 20" TV/VCR
DTV remote code
KZXten,
Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
Here's a link to the remotes Comcast is providing in my area.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Dec 23, 2007 | Panasonic PVQ-2510 25 in. Combo
"Line In" mode (on both TV & VCR) -- (Please help) "Get (them) Back to "Normal"!"
it sounds like you need to get a universal remote that has an av setting on it usuall this is 0 or an av button this shoud toggle between these modes sorry couldnt be any more help
Oct 31, 2007 | Televison & Video
Hitachi F361 VCR Digital Auto Tracking (not 631!)
I had the same problem when I got the TV from someone and I didnt have a remote. I went out and got a ONE FOR ALL remote and once I got it set up I had it in VCR mode and hit the AV button and now I can get to the channels. Hope it works for you.
Oct 31, 2007 | Hitachi VTFX631A VCR
1,894 people viewed this tip
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
