Tip & How-To about Computers & Internet
Watch Web Generated Movies on your Television
This is very simple. If you have a laptop..you can plug it into any newer television. All you need is any S Video cord and an audio/visual adapter. You then set your laptop settings to output to television (look in Control Panel, then monitor) and change tv channel to appropriate chanel.
Good Luck and once it works...who needs a big computer screen.
Computers & Internet Logo
Can I hook up my roku device to this tv If so what kind of cable do I need?
On the back of the TV/VCR unit there is an input for audio & video plugs. These will accept a composite video signal and mono audio signal. I'm not sure if newer roku has these outputs as they are low def only signals. The roku would need to have have red, white & yellow sockets. (Old Roku's had these....) Yellow is video, red and white are L & R audio. Use a y adapter to merge red & white together, and use a standard RCA patch cord to connect the roku composite outputs to the TV VCR inputs.
May 01, 2014 | GE 19TVR62 19 in. TV/VCR Combo
how to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
how to connect nintedo to plasma tv
Hi,things you will need,
  • Video game console
  • HDMI cable
  • Audio/visual cable.
  1. Plug in your video game console's power source.
  2. Connect one end of the game console's audio/visual cable into the corresponding slot on the console if you have an older game console. If you have a newer console, insert one end of an HDMI cable into your console's "HDMI OUT" port.
  3. Plug the red and white ends of the audio/visual cable into the corresponding red and white audio inputs located on the back of your Vizio plasma TV if you have an older game console. Plug the yellow cable into the yellow "Video In" input. Depending on which model of Vizio TV you have, the yellow input may be located either right next to the audio inputs or it could be located a few ports away.
  4. Plug an HDMI cable into one of your TV's "HDMI IN" ports, if you have a newer console.
  5. Turn on your video game console and your Vizio plasma TV. Press the "TV/VIDEO" button on your remote to cycle through the various inputs. You should eventually get to an input that's displaying your video game console's home screen.
I think that will do.
Have nice day.
Sep 25, 2010 | Nintendo Video Game Consoles & Games
connect my aspire 5332 to my digital tv
There are a few things that need to present or applicable for this to work.
First off you need to have either a HDMI cable that can be plugged into your TV( tv and laptop must have one for this option to work). And you'd need to have the channel on your TV set to which ever channel recieves HDMI input.
Second you could have a monotor cable with two ends to attach to your laptop and TV as well as an audio cable like you get for computer speakers to have a line in and a line out, you may need an adapter for the video, usually with newer tvs like my 25.5" LCD HDTV from Samsung they provided this cable and a adapter. After they are connected you'd still have to set the channel to the correct one for the input to receive a picture from your laptop for example my tv channel for my PC is called DVI and my HDMI connection is HDMI 1
If you dont have either of those then you would need an S video cord and a audio cord with it to connect your output (from laptop) to the input hole (into tv) for this to work. And the channel would have to correctly set again.
If none of these help please post in more detail.
check out my site!! http://ctrlr4repair.webs.com
May 05, 2010 | Computers & Internet
Picture but no sound after using a converter for the hdmi cord to plug into a television without a hdmi plug
Make sure you double check your Audio settings on your PS3 so that they are being output by HDMI.
If that doesn't work, it may be that the adapter/converter you're using does not support audio within its adapter (not plugged up to the audio ports on your tv) If that's the case, then you may want to look into either component/composite video/audio or a fiber optic cord for sound (if your tv can support this)
Apr 14, 2009 | Sony Playstation 3 (PS3) Console
146 people viewed this tip
David Payne
David Payne
