Tip & How-To about Samsung HL-P5063W 50" Rear Projection HDTV
Rear projection TV displays a shadow on one corner or side of the screen.
Hi.
This tip may be helpful only if your rear projection TV is displaying a darker shadow on one portion of the screen. If the shadow shape and size will not vary, that means that there is probably a detached mirror in the device called Light Tunnel, located inside your TV.
Most rear projection TV works projecting the light from the internal lamp on the screen. Before reaching the screen , the light will pass through a 'pipe' whose internal surface is covered in rectangular mirrors, located all over the tunnel surface.
A quite common fault is caused by one of the mirror detaching from the the light tunnel internal surface , and falling down or hanging in there. This will be seen on the display as a darker shade located near to one side of the screen.
The light tunnel is located in the light engine. To repair the problem the TV must be disassembled by a technician. Accessing and disassembling the light engine is not a repair that can be done by the owner.
Click here to view pictures of a light engine for a Samsung rear projection model. The tunnel is the optical device located in the light engine.
If you are a technician, to replace the light tunnel you will have to take apart the light engine, that apart of being quite a sensitive optical device, is also the most expensive part on a rear projection TV.
In that case you may find useful the service bulletin posted below, that is illustrating how to replace the light tunnel on a light engine for Samsung rear projection TV. Please be aware, that if you attempt doing this operation without sufficient knowledge and experience, you may damage your TV set beyond repair, as the light engine is very expensive.
How to replace light tunnel on a Samsung rear projection:SERVICE BULLETIN
The file is on PDF format.
Regards.
Ginko.
Samsung HL-P5063W 50" Rear Projection HDTV Logo
My TV has a shadow in the screen why??
Oh, you've got it!
Peter Pan has been looking for it.
No, but seriously... For the forum here to be able to assist you better, please provide make and model, and if available serial number for your unit.
and exactly, what do you mean by shadow: Is it even, is it a line, is it splotchy, is it just a darker portion of the screen and then other portions? Being specific will assist us, to assist you better.
Mar 31, 2015 | RCA Televison & Video
I have a blue streak going horizontally through the top portion of the screen with shadows behind it. It also looks like the screen is "darker" or more yellow to it.
Your loosing you blue CRT. High voltage adjustment may cure. Horizonal like is called retrace line. Lack of high voltage allows this line to be visible
Jun 23, 2009 | Samsung HC-P4752W 47" Rear Projection...
3LCD Projection TV 2.5 years old displaying blue hue/blobs
I would first try a new lamp. If the reflector portion of the lamp has any defects, it could show up this way as the light would not be uniform. The next possibility is a defective light engine. The engine portion if not field repairable and would need to be replaced. Try the lamp first and let us know what happens.
Dan
Jan 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Yellow and Blue shadow on left side of screen
Blue convergence off = needs convergence IC's replaced =
Would you like step - by - step how to ??????
Nov 07, 2007 | Toshiba 51H84 51" Rear Projection...
2 Problems with my Mitsubishi 65" widescreen projection tv
1. THE SYMPTOM IS BRIGHTER IMAGE ON THE SIDES AND DARKER IN THE MIDDLE. THE PROBLEM CAN BE WITH RED BLUE AND/OR GREEN. CHECK FOR PROPER CONNECTIONS TO THE "DAG COATING AND CONNECTIONS TO PIN 9 ON THE SOCKET OF THE AFFECTED CRT. MAKE SURE THESE GROUND POINTS ARE COMMON WITH CHASSIS GROUND
May 31, 2007 | Mitsubishi WS-65807 65" Rear Projection...
2,789 people viewed this tip
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
