Tip & How-To about Computers & Internet
Make osx dvd image in mac
Making a DVD Image...............
Step 1. Insert the retail Mac OS X Install DVD into your drive.
Step 2. Launch Disk Utility (Applications > Utilities).
Step 3. In Disk Utility, you will notice a white pane on the left hand side. In the pane, select the Mac OS X Install DVD by clicking on it once.
Step 4. Click New Image on the Disk Utility toolbar.
Step 5. A dialog box will appear. Give the new image a name. I used 'Mac OS X Install DVD'. Select the destination where you wish to save it. LeaveImage Format at Compressed (default) and Encryption at None (default).
Step 6. Click Save to begin creating the image.
Step 7. Once your image has been created DO NOT mount it. Leave the image alone and proceed to the next section.
Burning the Image...................
Step 1. Launch Disk Utility (Applications > Utilities).
Step 2. Click Burn on the Disk Utility toolbar (upper left).
Step 3. Navigate to where you saved the DVD image created in the previous section. Click on the image file, then click the Burn button. Do not drag and drop the image file into Disk Utility during this step.
Step5. Insert a DVD when prompted and proceed to Burn it. (use good quality media)
Using these exact steps I was successfully able to create a personal backup copy of Mac OS X Tiger. I hope this tutorial helps. Enjoy the newfound features in Tiger!
Computers & Internet Logo
my macbook shows a white screen and a sound only and after that nothing happens
JUST TRY TO FOLLOW THE STEPS IT WILL BE VERY HELPFUL
Many computer shoppers choose to buy a Mac not only to use OS X, but Windows as well. That is one strong advantage that Macs have in the Mac vs PC war. Apple computers are capable of running Windows, either through Bootcamp or virtual machines.
So, why aren't Windows PC's capable of running OS X? Well, Windows PC's are capable of running OS X. But, it is against Apple's licensing agreement to do so. Thus, this article is intended for educational and demonstration purposes only. If you want to run OS X the best way possible, get a Mac.
*In order for this to work, your computer must have a processor that supports virtualization. If it does not, you may receive errors. For the most part, any newer processor lines: Core 2 Duo, Quad Core, and Core i7 should all work fine.
But, don't expect to not get errors if you are using an older Pentium 4 machine. The processor must be Intel and not AMD*
Because we will be installing OS X on top of Windows through a virtual machine, the first step is to get some virtual machine software. For this demo, we will be using VMware's Workstation 7.
If you do not feel like purchasing Workstation 7 at this time, you can get a limited trial here. The download may take a good half an hour to complete. Workstation is a 512MB file.
Upon download, go ahead and install Workstation 7 onto your computer. The installation process is very simple just launch the installer, and the VMware installer will guide you through the rest.
One thing to note, when it asks your if you want to do a custom install or a typical install, choose typical install. After the installer finishes, restart your computer
Now that you have Workstation 7 installed, you need a pre-configured VMware virtual machine file to install Snow Leopard on top of. Download this file (alt download) and save it to your desktop.
After you have the pre-configured virtual machine file downloaded, you will need to extract the files using WinRAR or another archive utility. If you do not have an archive utility, you can get WinRAR here.
Note: This file is just a disk image framework, no viruses or anything like that. VMware Workstation uses the disk image format to save and contain virtual machines.
Time to start installing Snow Leopard. Launch VMware Workstation by using the path Start > All Programs > VMware > VMware Workstation. Open up the VMware disk image framework that you just downloaded and extracted.
Select File > Open. Navigate to your Snowy_VM folder, open it, open up the next folder that says "Mac OS X 10.6 Server (experimental).vmwarevm, and choose the 2KB file that is named Mac OS X Server 10.6 (experimental). Click the open button to load the virtual machine.
From the Mac OS X Server tab in the VMware Workstation window, click the edit virtual machine settings icon. You may adjust the hard drive size, memory, etc, to your liking.
Select CD/DVD (IDE) and under the Connection settings, select Use ISO Image File. Click the Browse button and navigate to the Darwin_Snow.iso which is located in your Snowy_VM folder. Click the Open button to select the virtual machine.
Now it's time to power on the virtual machine. Click the Power on this virtual machine option. As soon as the process starts, hold down the F8 key on your keyboard. You should be prompted with a boot menu screen.
If you have not done so already, insert your OS X Snow Leopard Install DVD into your computer's CD/DVD drive. So far, you have loaded a workable virtual machine and framework into VMware Workstation.
Now it's time to actually install Snow Leopard onto that virtual machine disk image. You should see some settings icons located at the bottom right portion of the VMware window. Right-click the icon that looks like a CD and choose settings from the pop up menu.
Go back into the boot screen and select the option C Boot from DVD. Press the F8 button on your keyboard for advanced options and type "-v" without the quotes and hit enter. Now, VMware Workstation should boot your Snow Leopard install disc. It may take a couple of minutes to load
That's all there is to it. You should now be at the normal Snow Leopard install screen. Click continue on the first screen that comes up. On the second screen, click the utilities option in the install window and select disk utility. Use disk utility to change the hard drive format type to OS X Extended (Journaled). Exit disk utility and let OS X install completely.
Upon install of Snow Leopard, your virtual machine will restart. After it restarts you will need to do a couple of things to get into Snow Leopard. Select CD/DVD options, like you did before, and use the Use ISO Image File option.
Sep 26, 2010 | Apple MacBook Mac Notebook
The power come on but the harddrive will not boot since there is nothing shows on the screen. The screen is blank, no apple sign, no sping gears. pls what do i do,and my mac os that comes with the system is bad.
With regards to the blank screen, this usually indicates an issue with the hard drive being faulty (hardware) or the OS might have corrupt system files (software).
These are the items you will need before we begin:
A. Mac desktop/laptop B. Mac OSX Installation DVD
A. Software Related
1. Power on the Mac computer/laptop and immediately press and hold the option key. 2. After about 15 seconds of holding the option key, release it and insert the Mac OSX DVD. 3. The DVD should load and display on-screen (along with any additional drives available on the system). 4. If the hard drive icon appears, then click on it. (if the hard drive boots the OS, then the issue is software related. Skip down to Section B, step #1). 5. If the hard drive did not appear, then the system does not recognize it. However, the DVD icon should have appeared, click on it. 6. The DVD will boot and begin the installation process. 7. Follow the installation prompts. 8. Once completed, the desktop/laptop will reboot and after logging in, will execute the registration process. 9. Complete the registration exercise and access the desktop. 10. Perform a software update and download all system and application updates to their latest versions.
B. Hardware Related
1. Power on the Mac computer/laptop and immediately press and hold the option key. 2. After about 15 seconds of holding the option key, release it and insert the Mac OSX DVD. 3. The DVD should load and display on-screen (along with any additional drives available on the system). 4. If the hard drive icon appears, then click on it. (if the hard drive boots the OS, then the issue is software related. Restart the computer and skip up to Section A, step #1). 5. If the hard drive did not appear, then the system does not recognize it. However, the DVD icon should have appeared, click on it. 6. The DVD will boot and begin the installation process. 7. Close the installation application and select "Disk Utility" from the "Utilities" menu option. 8. When Disk Utility loads, look to the left-hand pane and locate your hard drive (if detected). If so, click on it and format the hard drive then reboot and skip up to Section A, step #1. If the hard drive is not detected, then the hard drive has malfunctioned and needs to be replaced.
Hard drive's cost from $40-100 for sizes ranging from 40GB to 1TB. Once the hard drive has been replaced, you can install OSX from the installation DVD.
Aug 11, 2010 | Apple PowerBook G4 Mac Notebook
used bootcamp and tryed to install windows and got disc error ,now wont go back to normal statas. how do i fix?
Insert the Mac OS disk in the drive and reboot while holding down the C key. This will launch your computer in Mac OS and then you can access Disk Utility from the startup window.
Rebuild/ repair as needed, then I suggest removing any partition that you may have set up and re partition your drive for the windows stuff. Give yourself ample room on the harddrive for your windows software and files.
Be sure to print out a copy of the instructions for bootcamp before you launch... also be sure to allow it to automatically set up your mac for windows. Do this:
1.set up a partition according to the directions for bootcamp
2. install windows as per bootcamp instructions
3. after it's launched in windows, insert the Mac OS disk and it will launch all the setup for your mac hardware to run windows... modem, wifi, all that mojive that you usually need to spend hours in PC land ..mac will set it up for you.. Also download a copy of Bonjour from the Apple site. this will set up your printers for use in windows very easily and quickly..
The main thing is follow the directions and let the computer do all the setup...
May 21, 2010 | Apple iMac (MA876LL) 20 in (MA876LLA) Mac...
hi We have a Powermac G4 (mirrored drive doors) with dual 887MHz processor and 2 hard drives. running MacOS X10.4.11 Graphics NVISIA AT4 MX Pro AGP (DVI &ADC) the second/slave hard drive has an image of OS X10.4 tiger installer. When it is switched on we eventually get the apply logo and the timer icon spins at first with ? then it goes to blank screen with the timer icon spinning and will go no further. We have tried to swap hard drives round but it making no difference. We do not know how to get into the system or what else we can do. we do not at this time have the discs Any advice on what the problem could be and how we deal with it preferably without lose of files would be gratefully accepted. thanks
Sounds like the hard drive may be on it's last leg. You're going to need an OS on a second disc if you're not able to launch from the existing one.
If you can get the Mac OS disc dvd, you can start up your computer while holding down the C key and it will launch on the DVD system and you can install the system software onto a new drive (or your second existing drive).
Once the computer starts up normally on the other drive, you may be able to access the failing drive and pull files... it may take a while and stop alot but you may be able to save it.
Nov 27, 2009 | Apple Power Mac G4 Desktop
192 people viewed this tip
David Payne
David Payne
