Tip & How-To about Computers & Internet
How to set up wireless home network with a DSL subscription.
If you have a DSL, "Digital Suscriber Line", most companies will provide you with a modem. Usually the modem will have only one ethernet connection, meaning you can only connect one computer.
In order to connect multipule computers you will need a wireless router, ethernet HUB, or router.
Connecting with wireless Router
The only thing you really need to change is the following 3 settings on the Wireless Router. The SSID (so you know what wireless network is yours), the WPA/PSK and or WPA2/PSK, encryption method TKIP key or password. Under "administration" change the administrator password for a secure wireless connection. ( WRITE DOWN YOUR PASSWORD)
Connect to your wireless router
1. Plug in either your (1) wireless card, (2) PCMCIA wireless card, or (3) USB wireless stick.
2. Turn on your laptop or desktop computer. Select the wireless router with the strongest signal and with the name of your routers (SSID) and click connect.
3. Open your web browser and type 192.168.1.1
If this dosn't work, check your wireless router instruction manual for the correct IP address for your model.
4. Your router will ask for a password, usually (admin, admin) works or (admin, (ENTER) ) try both. If neither work try resetting the router by holding in the reset button for 3 seconds.
Once you log on to your router you can set parameters to your liking or just set the , {SSID}, {WPA/TKP} key or password, and the router administrator password to keep others from accessing your network and possibly computer.
Ethernet
Start at step 3 above.
More questions?
Computers & Internet Logo
i have a Dell inspiron 537 sesktop pc and the lan adapter is not recognizing the ethernet lan connection. I reinstalled the drivers etc but it still show " not connected ". Is there anyway to solve this problem ?
To connect to the Internet, certain hardware and services are needed, which are listed below. Without any one of these items, connection to the Internet is not possible.
  • Broadband Internet Service (also known as Internet Service Providers or ISP) - Telephone companies (also known as DSL, which uses a telephone line) and cable TV companies usually offer Internet service.
  • Broadband Modem - Normally, a broadband modem can be rented or purchased from the ISP.
  • Computer with a Network Adapter - This is usually a device located inside the computer.
  • Broadband Router - A router is used to connect all of your computers to the network (but is not needed for a single computer). The router also provides a way to connect to the Internet through the Broadband Modem.
Oct 12, 2011 | Dell Inspiron 537 (DDCWQA1_7) PC Desktop
won't connect to internest.
first there should be 2 cables connected the device.
1) power adapter
2) ethernet cable from either a dsl modem or a cable modem connected to the wan connector
with most cable modem service its usually dhcp meaning you are always connected to the internet
with some there is ppoe connection where a user name and password is used to make a connection to be on the internet with the dsl modem
there are some dsl companies that are dhcp just like the cable modem companies.
with the ethernet cable connected the wan port on your router there should be some kind of activity light on the router but check with the type connection from your dsl or cable internet provider. also you will need a second ethernet cable to connect your computer to setup and configure the wireless settings and wep protection.
need more info?
Aug 24, 2011 | NetGear WNR2000 Wireless Router
yes i want to find out if a cable modem will work with your dsl phone internet service?
No.
A cable-modem connects with a coax-cable to the cable-company's network, but a DSL-modem connects with telephone-cable to the telephone-company's network.
Jan 27, 2009 | AT&T High Speed DSL Modem
My modem sometimes work and sometime show only two lights i.e. power and ethernet and do not connect to my dsl internet
Do you know if you have line issues with your phone company? If you're at the outer edges of DSL range from the Central Office, your connection might be dropping. The fact that the power and ethernet lights stay lit shows that the connection might not be on your end. Does the connection get reestablished when you reboot the modem? You may have to get your provider to do connectivity tests on your line.
Jan 04, 2009 | Computers & Internet
171 people viewed this tip
David Payne
David Payne
