Tip & How-To about Computers & Internet
Cleaning battery contacts to keep your laptops, portable dvd players, etc operating properly
Cleaning battery contacts is an important general maintenance procedure and should be done about every 6 months. The following are some reasons why you should keep battery contacts clean. The steps provided in this tutorial applies to any battery operated device.
1. Cleaning the contacts keep the devices that use the batteries working properly.
2. Keeping the terminals/posts and contacts clean from corrosion can help extend the life of the battery, especially rechargeable ones.
3. Keeping the contacts clean will save you a lot of time and money in the long run.
Battery contacts come in different shapes, sizes, configurations, and are made from different materials. The following picture shows you some examples:
Example of a spring end of a battery contact:
Keeping rechargeable batteries and the contacts clean can extend the life expectancy of the batteries and keeps the device operating properly. The following is a chart that demonstrates the life expectancy for lithium-ion rechargeable batteries commonly used in laptops:
Picture of a laptop battery and it's contacts:
If batteries and the contacts become dirty or build up corrosion, the battery can no longer make a proper contact. This causes the battery to loose their charge faster and also prevent the device from receiving the proper voltage and prevent it from operating properly.
You can purchase products to help clean the batteries or contacts. The following shows you some examples of a battery cleaning product and a battery contact cleaning pencil. You can actually use a regular pencil eraser to clean battery contacts if you want.
Battery contact cleaning pencil:
Cleaning steps:
1. Make sure you have the proper tools you might need to access the batteries or contacts. Wearing gloves and eye protection is always a good safety precaution when handling batteries.
2. Make sure you have a flat, clean surface to work on with adequate lighting.
3. Remove the device cover to the battery compartment and remove the battery.
4. Check the batteries for burnt spots, leaking, bulging, cracks or breaks. If you see any of these, discard the battery because it will need to be completely replaced. These are indications that the battery is no longer serviceable and failure is imminent.
5. Check the contacts for any signs of damage such as breaks in the metal, broken springs (if applicable), etc. If any damage is found, replace the contacts before continuing to use the device.
6. Using the pencil eraser end, clean the tops and bottoms of the batteries (or if you have purchase a special battery cleaning product, follow the directions).
7. Next, tilt the device you are cleaning (if possible) so that any debris will not fall further into the device. Take the pencil and clean the contacts in an outward motion to help sweep dirt, corrosion, etc away from the device. You can use a small keyboard vacuum to help clean the inside of the battery compartment also.
8. If the pencil eraser is not cleaning the contacts due to large amounts of corrosion, you can use a small piece of metal (this should be the last resort). You gently scrape away any corrosion or packed on debris from the contacts. Exercise extreme caution to not damage the contacts by severely scratching or breaking them.
9. If you are cleaning a 12 volt car battery, you can apply the same measures as mentioned. If you are having trouble removing debris, you can use a wire brush to gently remove it.
10. You can now replace the batteries into the compartment and replace the device cover.
CAUTION: It is not advisable to use chemical cleaning solutions on batteries.
Following these steps and regular preventative maintenance on your batteries and device can help ensure a longer life expectancy for the batteries and longer use of your product.
Computers & Internet Logo
Is there a manual for preventive maintenance?
every 3 months and more in the summer I spray my outside unit with a garden hose. I start at the top of the grill and work my way down. dirt and grime will come out the bottom. jeff
May 27, 2013 | Ruud UAKA048 Air Conditioner
The prints are coming out distorted and not aligned. Have tried print head, deep cleaning and nozzle check. Cartridges are over 6 months old though.
You must align the printing heads - the option is there, in the same Maintenance window as the cleaning one. Follow the procedure.
May 02, 2011 | Canon PIXMA iP3300 Printer
may go for 6 months ok then does random reboots
I would suggest shutting down at least once a month for general maintenance such as dusting the fans off and cleaning the computer case.
If you are running for 6 months straight with out a single shut down that is negligence on your behalf to your computer & to the hardware inside. A lot of dust that accumulates may not seem like much to you but the amount that does accumulate will damage the hardware given enough time.
I hate to think of how much dust is accumulated inside it I like to give my PC a light cleaning each month. Generally a few quick hits with a compressed air canister is enough to keep the PC dust free.
Sep 16, 2010 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
cannot uninstall
Hi there!
If you plan on reinstalling Nero 6, please follow the procedure here to find and write down your serial number:
http://www.nero.com/enu/support-nero6-tools-utilities.html
If you just want to completely delete Nero 6, you can use the Nero General Clean Tool available from Nero here:
ftp://ftp6.nero.com/tools/General-CleanTool.zip
Feb 17, 2009 | Ahead Software Nero 6.0 (60045) for PC
not feeding
Have you still getting the problem, have you done cleaning of Cartridge, its nozzle and Contact strip.. then cleaning of Printer roller or carriage rack.. Do a Service of it or get it done by Technician.
Also check the feeder tray.. to grab paper one by one by printer.. Manually
Take all updates for printer and OS.
Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
3,712 people viewed this tip
David Payne
David Payne
