Tip & How-To about Computers & Internet
Computer Repair Services
Computer repair includes software and hardware repair. Hardware repair is needed when any part of the computer is not functioning as expected. Software repair is required when any software program is not executing properly.
Need of computer repair
Computer repair is needed for making your computer function properly. Your computer will function properly if all its parts are working properly. Some of the issues for which you require computer repair are as follows:
• Computer automatically shuts down
• Computer takes much time in launching applications
• Computer system crashes or locks up
• Blue screen error
• Computer makes beeping sound when switched on
The reason for most of the computer issues is the lack of maintenance. For maintaining your computer and optimizing its performance, you have to update software regularly, clean registry, empty cache files and many others.
In case, you have the knowledge about how to repair your computer, you can perform it yourself. But if you do not have any knowledge in this field, then you can contact a computer support technician.
Computer repair technician is a person who will repair your computer either through online or on-site. Online computer repair is preferred in case your computer needs software repair. If you want to go for online computer repair, all you need to have is an Internet connection. Online computer repair saves your from the pain of taking your computer to some technical services center or inviting some technician at your own residence.
These days most of the companies offering online computer repair adopt the method of remote desktop connection. Technician will access your computer with the use of software made for remote desktop connection. But you have to give him permission for doing so. After getting permission, he will diagnose your problem and after that resolve it. Technician will install, reinstall or uninstall any software, or modify some of the settings for resolving issues.
In case of hardware repair, you have to call a technician in your premises. Technician will diagnose all of your peripheral devices, in case of any faulty one, he will replace that one. He will also update drivers of peripheral devices.
So, it can be said that computer repair is required when your computer is not functioning as expected.
Computers & Internet Logo
what is the operating machine ?
If you mean operating system then:
An operating system (OS) is a set of software that manages computer hardware resources and provides common services for computer programs. The operating system is a vital component of the system software in a computer system. Application programs require an operating system to function.
Time-sharing operating systems schedule tasks for efficient use of the system and may also include accounting for cost allocation of processor time, mass storage, printing, and other resources.
For hardware functions such as input and output and memory allocation, the operating system acts as an intermediary between programs and the computer hardware, although the application code is usually executed directly by the hardware and will frequently make a system call to an OS function or be interrupted by it. Operating systems can be found on almost any device that contains a computer-from cellular phones and video game consoles to supercomputers and web servers.
Examples of popular modern operating systems include Android, BSD, iOS, GNU/Linux, Mac OS X, Microsoft Windows, Windows Phone, and IBM z/OS. All these, except Windows and z/OS, share roots in UNIX.
Jun 24, 2012 | Computers & Internet
what is software?
Hello
Computer instructions or data. Anything that can be stored electronically is software. The storage devices and display devices are hardware. The terms software and hardware are used as both nouns and adjectives. For example, you can say: "The problem lies in the software," meaning that there is a problem with the program or data, not with the computer itself. You can also say: "It's a software problem." The distinction between software and hardware is sometimes confusing because they are so integrally linked. Clearly, when you purchase a program, you are buying software. But to buy the software, you need to buy the disk (hardware) on which the software is recorded. Software is often divided into two categories: systems software : Includes the operating system and all the utilities that enable the computer to function. applications software : Includes programs that do real work for users. For example, word processors, spreadsheets, and database management systems fall under the category of applications software.
Hope this helps
Jan 26, 2011 | Office Equipment & Supplies
just downloaded software update<and restart.now
  1. The computer is freezing though the component parts are designed to withstand motion picture malfunctions known as freezing. Computers with enormous hard disk spaces to contain several user programs are least likely expected to experience freezing conditions. Also, computers with improved graphics, sound media, video hardware components least should experience multimedia malfunctions. Freezing occurrences on computers have several causes discussable.
Usually a functioning computer requires components mentionable as hardware's that are the visible aspects, and software's that may have been installed to take a visual display format. A functioning computer would usually have the software's integrated into the hardware's from the manufactures facility. For example, acquiring a computer from retail would be in functioning mode with every component parts intact as default built for the user. However, once a functioning computer begins to malfunction would be due to either hardware component or software components. The conditions that could make computers freeze are conditional. First, freezing malfunctions are caused by software overloads resulting in a hardware overburdenment. For example, the computer would have been installed with programs at the manufacturer as operating systems that make functionalities possible. Once the computer was turned on prior to the user interactions, what is displayed is the operating systems usually a manufactures default feature. However, the computer is provided with spaces as an expectation for the user to achieve experiences several mentionable. For example, the computer user is provided spaces on computers for productivities purposes mentionable with office or school resources manipulations. A specific amount of space from the manufactcturer was placed to allow for the operating system to be alterted should any occurrences arise. Alterternately, the user interfaces has spaces allocations for manipulations discussable. First, filling up the computers spaces produces least performance either extensively display programs without continuous transition like as before with default functionality. Saving several programs on the available spaces causes freezing due to least spaces for motion to occur For example, the type of media on the computer may actually take extensive spaces. Motion pictures simply require enough computer space to be saved, thereafter displaying like expected else would produce still images also thought as freezing since not every motion is capable of displaying entirely with spaces provided however. Second, a download of a virus may cause the computer to freeze sending a response to the user that the spaces on the computer are full while in fact, the virus was perhaps designed to perform as impediment to usually space accessibility required for the entire computer to display appropriately. So far the explanation has been about the causes of software malfunctions that display results on the screen noticeable as freezing images. Alternately however, the computer may still appear frozen with hardware malfunctions discussable. First, the computer hard disk stores the operating systems programs installed at the manufactures. Once the hard disk programs are damaged either describable as crashes due to physical exposure, impact, or simply out dated, the computer may display remnants programs least achieving user desirable experience. Hard disk conditions includes that the physical wiring to the motherboard have come loose. Inspecting the disk connections to ascertain very component parts are intact would be likely diagnostic for hardware's malfunction also explainable for freezing computers. Several components within the computer once over burdened causes motion sluggishness. For example, the graphics hardware mentionable as memory cards, video cards, or multimedia readers may have become outdate for reasons discussable. First, the computer may have space for several programs. However, installing multimedia programs would require improvements such components as media readers to achieve desired experience.
Jan 23, 2011 | Computers & Internet
widows freezes, repeats disk check
Jan 20, 2011 | Gigabyte GA-G31M-ES2L Motherboard
can u brief me about drivers
Computer drivers are software programs. It helps a computer identify and run the hardware installed in it. For Example, without drivers the computer will not be able to distinguish between a sound card and a modem. Most devices on the computer need drivers to run. Computer accessories, such as printers, scanners and digital cameras also need drivers to function. All computer hardware and accessories that is purchased comes with drivers either in a floppy or a CD. The computer automatically loads the drivers when inserted in the drives. Drivers can also be downloaded from manufacturer's websites. You can download the most recent or updated drivers for a hardware.
Jul 11, 2009 | Computers & Internet
1,472 people viewed this tip
David Payne
David Payne
