Tip & How-To about Cameras
Method of importing MTS and M2TS files to iMovie
Since iMovie’08, Apple has announced that it works with many tapeless camcorders that record to flash memory, HDD, or DVD media, including camcorders using MPEG-2 (standard definition) and AVCHD (high definition) formats. With the release of iMovie’09, it expands supported camcorder formats to MPEG-2 (standard definition), AVCHD (high definition) as well as MPEG-4 and H.264 formats. However, at the same time, Apple also remind users that due to the wide range of media types, and the different ways manufacturers store video on these media types, not all tapeless camcorders are compatible with iMovie '08 and iMovie’09. AVCHD camcorders are among this range. AVCHD format (.mts, m2ts) has been a headache to some Mac users for not a short time, especially for people who are in use of an old PowerPC, because AVCHD format can only be supported by iMovie with an Intel-based Core Duo processor or better.
Fortunately, more and more video converters are designed to help Mac users solve this problem, Pavtube MTS/M2TS Converter for Mac is one of them which performances very well. No matter what version of iMovie you are in use, and what Mac system you are working on, it will assist you to import your MTS/M2TS AVCHD files to iMovie for editing smoothly. Now please follow its step-by-step instruction as you like.
First of you, free download Pavtube MTS/M2TS Converter for Mac here, and then install and run it. Notice that there are two versions, both PowerPC and Intel, pay attention to choose the right one to download.
Step 1: Load MTS/M2TS files, select iMovie workable format
You can directly drag and drop MTS and M2TS file to this program or you can click “Add” button to import files. After that choose an iMovie supported format to convert. You can choose MP4 or MOV, and here I select MOV for instance.
Suppose you’d like to combine all the added files to be a single file, so that you can import them to iMovie for editing once only. In that case, please tick the checkbox of “Merge into one file” to realize it. Also, if you do not want the save path set by default to store the output files, you can click “Browse” button to look for and specify a destination folder.
Step 2: Adjust video and audio parameter
This program allows users to set advanced settings, that is to say, you can insert your preferred options to items in the interface below, including bit rate, frame rate, sample rate, channels, etc. The output file size will be enlarged if you adjust the figures to be larger, also the file quality will be improved at the same time. On the contrary, if you adjust the values to be smaller, the output file size will be decreased, but accompanying with inferior output quality.
Step 3: Convert
After the above two steps are done, you can click “Convert” button to start conversion. And the generated files for iMovie can be got via press “Open” button.
Tips:
1. The program adopts advanced audio and video sync technology, and never lets your video and audio go in separate way.
2. This program optimizes its conversion speed with multi-thread technology, so that you can convert MTS/M2TS AVCHD files 1.5 or 2 times faster than other similar programs.
3. Its trim and crop functions allow you to select the proper time length for MTS/M2TS videos, as well as cut off any unwanted areas. Its original video and output video preview windows will also be convenient for you to edit.
4. It Provides users with simple gauss blur effect, which is very useful to recorded files, since it can eliminate the noise of recorded videos. If you like, you can also add other special effects including simple laplacian sharpen, gray, flip color, invert, aged film, etc. to your video files.
5. It allows users to add various watermarks, such as text watermark, image watermark, GIF animation watermark and video watermark.
Cameras Logo
transferring video from camera to intel iMac
Some very useful relevant information here:
http://discussions.apple.com/thread.jspa?threadID=1397298
macs2u
Dec 20, 2008 | Sony HDR-SR11 Flash Media Camcorder
How to convert MTS and M2TS files to QuickTime for editing in iMovie Trace back to iMovie'08, Apple has announced that this bundled video editing software works with many tapeless camcorders that record to HDD, flash memory, or DVD media, including camcorders using MPEG-2 (standard definition) and AVCHD (high definition) formats. With the release of iMovie'09, it expands supported camcorder formats from MPEG-2 (standard definition), AVCHD (high definition) to MPEG-4 and H.264 formats. However, it does not mean that iMovie will be an all-pass application to any sort of camcorders and cameras. Due to the wide range of media types and the different ways manufacturers store videos on these media types, Apple has reminded users that not all tapeless camcorders are compatible with iMovie'08 and iMovie'09. AVCHD camcorders which capture footages in the format of .mts/m2ts are among this range to some extent. To make it possible for Mac users to edit MTS/M2TS files shot by AVCHD cameras in iMovie, this guide will provide a solution to the problem of how to convert MTS/M2TS files to QuickTime on Mac for editing in iMovie. What you will need is Pavtube MTS/M2TS Converter for Mac. Read on the following contents to find out a step-by-step instruction. Step 1: Click "Add" button to import MTS/M2TS files to this program Step 2: Select QuickTime (*.mov) as output format for iMovie Click on the drop-down list of "Format", and follow "Common Video" > "MOV-QuickTime (*.mov)". Step 3: Set advanced settings Click on "Settings" button, and afterwards you can adjust audio and video parameters including video/audio codec, resolution, video/audio bit rate, frame rate, sample rate and audio channel on the following window. By the way, if you?d like to combine all the added files to be as a single file, you can tick the checkbox "Merge into one file" to realize it. Also, if you do not want to use the default save path, you can click "Browse" button to look for and specify a destination folder. Step 4: Convert After the above steps are done, you can click "Convert" button to start conversion. And you can click "Open" button to get the generated QuickTime .mov files effortlessly. Afterwards, just import the output files to iMovie for editing. Click here to see How to edit videos in iMovie. Additional Tips: 1. The program adopts advanced audio and video sync technology, and never lets your video and audio go in separate way. 2. This program optimizes its conversion speed with multi-thread technology, so that you can convert MTS/M2TS AVCHD files 1.5 or 2 times faster than other similar programs. 3. Its trim and crop functions allow you to select the proper time length for MTS/M2TS videos, as well as cut off any unwanted areas. 4. It Provides users with simple gauss blur effect, which is very useful to recorded files, since it can eliminate the noise of recorded videos. If you like, you can also add other special effects including simple laplacian sharpen, gray, flip color, invert, aged film, etc. to your video files. 5. It allows users to add various watermarks, such as text watermark, image watermark, GIF animation watermark and video watermark.
Nidesoft Total Video Converter is a extremely super Video Converter software that supports all popular video and audio formats. This powerful video tool accept: MP4, AVI, MKV, FLV, MOD, WMV, RMVB, FLAC, VOB, MP3, AAC, OGG and many other video files and audio music formats and convert them with unmatchable speed and high quality.
Apr 08, 2010 | Computers & Internet
97 people viewed this tip
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
