Tip & How-To about Computers & Internet
Simple Tips to Increase Your Computer Performance
You have a lot of work to get done, and the last thing you need getting in your way is a slow computer. There are several steps you can take to increase and improve the performance of your computer.
The first thing you can do to give your computer a boost is to add more RAM. RAM is pretty inexpensive, and having more of it available to your computer can make a real difference in the speed your machine functions at. Aside from buying and installing more RAM (or having the store install it), here are a few basic things you can do to get your computer moving.
The first thing you should do is go through your computers files. That's right. It's time to clean house. If you have lots of programs installed that you don't use anymore, uninstall them. Many programs have an uninstall option right in their Start Menu folder. If the program doesn't, use the "Add/Remove Programs" option in your computer's control panel. Doing this can clear up a lot of sluggishness.
Go through and delete old files you don't need anymore. Audio and video files are big ones that take up a lot of room on your computer and may slow things down some. Once you've finished "cleaning house" so to speak, it's time to take out the trash.
Empty your Recycle Bin. The icon is usually located directly on your desktop. Some operating systems place it on one of your menu bars, so look there if you don't see it on the desktop. You can right-click the Recycle Bin and instruct it to empty. The Recycle Bin gets very, very full if you don't empty it periodically. Clearing it can help speed up your computer.
The next thing you'll want to do is clean up files associated with your internet browser. Exactly how you will do this varies depending on your browser, but you'll probably go to "Tools" then "Options" or "Edit" then "Preferences." Look for an option to clear your private data.
You can clear your cookies at this point if you'd like, but you don't have to. What you do want to clear is your cache, and any offline content or temporary files. These are files that are stored on your computer so that web pages load faster, or so you can browse some sites offline. Many of these pages are web sites you went to one time and will never go to again, so you don't need to keep all the images and data associated with that site.
Next do a disk cleanup. In Windows you're going to find this under Start, All Programs, Accessories, System Tools. Look for "Disk Cleanup." Select that and let it run. It looks at how much space you can clean up and advises you on the best option for you. Choose to let it delete the files it suggests, and check off any you want to delete, then click OK and let it work.
Run a disk defragmentation after your disk cleanup. You can find this option in the place you found the disk cleanup. It can take a long time because it is shuffling things around on your hard drive to organize it and make your computer run more efficiently. This often frees up space and helps your computer work more efficiently. It may be prudent to start this before you go to bed and let it run overnight!
Two more steps to take to get your computer running at top-notch are the spyware scan and the anti-virus scan. It's pretty easy to get infected with spyware, so doing a period check on your computer is a good idea. After the spyware scan, run a full virus scan. You can request that your virus software do this after your spyware scan even if the virus software does a regularly scheduled scan. You may want to let these two processes run overnight, too.
After you've finally finished with all this cleaning and scanning, it's time to reboot your computer. Hopefully once it restarts you'll be pleasantly surprised at just how quickly it's moving along!
Computers & Internet Logo
why does it take my computer a long time to boot up, loading, and shutting down?
indicates that then hard drive is on the way out
first step is to save everything onto an external hard drive
then take it to a computer repair shop for an inspection
check how much space is on the hard drive because if you have a lot of junk on it , that slows down the start up and shut down p[rocesses
you can go to device manager and do a defrag of the hard drive to free up space
Aug 09, 2017 | Time Computers & Internet
I need to reset back to Factory spec's how is this done? I done something wrong last night and now is doing a lot of wired things. Can you help me. Don't know a lot about these things
just try formating the mobile/tablet from the recovery mode or what ever based on your mobile brand but unfortunatly after that step you will lose all your data after this move
May 24, 2016 | Tablets & eReaders
my mac is very slow. especially when playing videos. the videos are very choppy. is there anything that can be done to fix this?
Well, there are many reasons that may causing a Mac computer running slow, but generally two factors: hardware part & system part. For hardware part: I guess it's OK if your Mac is not that old. For system part: there might be a lot of junk files, caches, registry errors... out there which largely slow down any Mac machines. Actually about 80% slow Mac caused by this reason, if so, try cleaning the system. Learn more from: http://www.howtospeedupmac.com/ good luck!
Jul 13, 2011 | Apple iMac Desktop
very slow , how to remedy
download and run a program from "cnet.com" it is called ccleaner this is the first thing to do, after this is done you will need to get another program called malwarebytes again from cnet.com. this program will take about two hours to run and will remove all the spyware on your computer. the last thing is to run "msconfig" from the run command. if you haven't done this before google it to get a step by step guide. let me know how you get on.
Aug 10, 2010 | Acer Aspire 3613WLMi Notebook
slow computer
Do a deep virus scan. Install and scan with Windows Defender (free from microsoft) you probably have a virus and or spyware slowing it down. After running those 2 times each, if it's not a lot better you will need a Tech to clean it up.
Dec 10, 2009 | Office Equipment & Supplies
193 people viewed this tip
David Payne
David Payne
