Tip & How-To about Computers & Internet
Increase your youtube,metacafe buffering speed..........
You can increase the buffering speed of uploaded videos try it
steps
  1. start
  2. run
  3. type--system.ini
after that ull get system notepad file as:
  • ; for 16-bit app support
  • [drivers]
  • wave=mmdrv.dll
  • timer=timer.drv
  • [mci]
  • [driver32]
  • [386enh]
  • woafont=dosapp.FON
  • EGA80WOA.FON=EGA80WOA.FON
  • EGA40WOA.FON=EGA40WOA.FON
  • CGA80WOA.FON=CGA80WOA.FON
  • CGA40WOA.FON=CGA40WOA.FON
just below this copy this:
  • page buffer=1000000Tbps
  • load=1000000Tbps
  • download=1000000Tbps
  • save=1000000Tbps
  • back=1000000Tbps
  • search=1000000Tbps
  • sound=1000000Tbps
  • webcam=1000000Tbps
  • voice=1000000Tbps
  • faxmodemfast=1000000Tbps
  • update=1000000Tbps
so totally it will look as:
  • [drivers]
  • wave=mmdrv.dll
  • timer=timer.drv
  • [mci]
  • [driver32]
  • [386enh]
  • load=1000000Tbps
  • save=1000000Tbps
  • back=1000000Tbps
  • sound=1000000Tbps
  • voice=1000000Tbps
save the notepad file and reboot your system
Computers & Internet Logo
increase internet speed
Hi,do the following step by step instructions to increase your Internet Speed:
Step 1 : First of all Click on start button.
Step 2 : Select the run button from the start menu or type Run and click on it.
Step 3 : Type gpedit.msc
Step 4 : Expand the Administrative Templates branch
Step 5 : Now expand the Network branch
Step 6 : Click on the Qos packet scheduler
Step 7 : Double click Limit reservable bandwidth
Step 8 : Check the enabled
Step 9 : Change bandwidth Limit to 0 %
Step 10: Click the Apply button and OK.
Step 11: Now restart your PC.
Step 12. check if its now better.
Before and after doing these steps check your internet uploading and downloading speed results in both MBps and Mbps units from Scanmyspeed.com .
Dec 23, 2013 | TP-LINK Computers & Internet
tell me , what type software use to increase downloading speed up to 200 k b/sec . connection speed 921 k b/sec
With 921 kb/sec(which means kilobits per second) connection, the maximum download speed you would get is 921/8 = 115 kilobyte per second (kB/sec). Even to attain this much speed, you will have to use some download accelerators like Free download manager. You can download that and use it for free at http://www.freedownloadmanager.org/download.htm
Regards
Sherbaz
Aug 08, 2010 | Computers & Internet
my server can't boot
Hi ,
You have not mentioned which Operating System . If its for 2003 follow the steps.
To install the Recovery Console as a startup option:
  1. While Windows is running, insert the Windows Server 2003 CD in the computer's CD or DVD drive.
  2. Click Start, and then click Run.
  3. In the Open box, type the following line, where drive is the drive letter of the computer's CD drive or DVD drive that contains the Windows Server 2003 CD, and then click OK: drive:\i386\winnt32.exe /cmdcons
    To install Recovery console as a startup option for Windows Server 2003 x64 edition, type the following line: drive:\amd64\winnt32.exe /cmdcons
  4. Click Yes when the message appears, to install the Recovery Console.
  5. When you receive the message that states that the Recovery Console is successfully installed, click OK.
  6. To use the Recovery Console, restart the computer, and then use the ARROW keys to select Microsoft Windows Recovery Console in the Please select the operating system to start list.
uparrow.gifBack to the top How to Remove the Recovery Console loadTOCNode(2, 'summary'); As a precaution, do not remove the Recovery Console. However, if you want to remove the Recovery Console, you must do so manually.
To remove the Recovery Console, follow these steps:
  1. Restart the computer.
  2. Click Start, and then click My Computer.
  3. Turn on the Show hidden files and folders option (if it is not already turned on). To do so, follow these steps:
    1. On the Tools menu, click Folder Options.
    2. Click the View tab.
    3. Click Show hidden files and folders, click to clear the Hide protected operating system files (Recommended) check box (if it is selected), and then click OK.
  4. Double-click the drive letter that represents the hard disk on which you installed the Recovery Console.
  5. Delete the Cmdcons folder from the root folder, and then delete the Cmldr file. To do so, follow these steps:
    1. Right-click Cmdcons, and then click Delete. Follow the instructions that appear on the screen, and then click Yes to confirm the deletion.
    2. Right-click Cmldr, and then click Delete. Follow the instructions that appear on the screen, and then click Yes to confirm the deletion.
  6. Remove the Recovery Console entry from the Boot.ini file. To do so, follow these steps.
    WARNING: Incorrectly modifying the Boot.ini file may prevent your computer from restarting. Make sure that you delete only the entry for the Recovery Console.
    1. At the root folder, right-click the Boot.ini file, and then click Properties. Click to clear the Read-only check box, and then click OK.
    2. Open the Boot.ini file in Notepad.
    3. Locate the Recovery Console entry, and then delete it. The Recovery Console entry looks similar to the following line: C:\cmdcons\bootsect.dat="Microsoft Windows Recovery Console" /cmdcons
    4. On the File menu, click Save, and then click Exit to quit Notepad.
  7. Change the attribute for the Boot.ini file back to Read-only. To do so, right-click Boot.ini, and then click Properties. Click to select the Read-only check box, and then click OK.
Oct 12, 2009 | Acer Altos G710 Server
I can 't open file extension .ini in windowes xp
Here is a link to someone with the same problem and the solution: http://www.windowsbbs.com/windows-xp/70739-ini-extension-files-does-not-open-notepad.html
You can start by clicking start, then click run, and type regedit and press enter. Then expand the HKEY_Classes_Root folder and look for .ini, Click on .ini and make sure it is the following:
Default REG_SZ inifile
PerceivedType REG_SZ text
Let me know if you need more help. If this was helpful please rate, thanks!
Shawn
Jan 13, 2009 | Computers & Internet
192 people viewed this tip
David Payne
David Payne
