Tip & How-To about Panasonic LF 1196C PD (Rewritable) Burner
Problem with WinXPpro, don't recognize PD optical disk
With Win2000 PD-CD LF 1196C works well, but when l install new operating system WinXPpro only works de normal CD but the PD 650Mb optical disk no more work. l will be gratefull because l have too many data in PD disks to backup to DVD.
Thank you for any help on that
Computers & Internet Logo
Boot disk failure. Insert system disk and hit enter
Remove the CD player, open it and try cleaning the lens then put it back and try again if it doesn't ,convert the cd image to Flash disk using Rufus a free tool from the internet, then install your o.s using Flash disk.
Jul 17, 2016 | Microsoft Windows 2000 for PC
a cdr630 twelve years old will not record on any blank discs optical fail on maxell tdk and all brands.do you know what discs i can buy for this machine.marantz state discs with a green dye but i cannot find any.
The manual states that 74 minute 650MB 1-4X disks run best; my machine would not burn anything I had, eventually I found 650MB crrw's on ebay for as cheap as 2 cents a piece, I have a fair number of them and so far every single one has worked. Imation 800Mb cd's seem to work 80% for me.
May 20, 2010 | Marantz CDR631 CD Recorder
how can i change windows vista home premium to windows xp
If you have the Windows XP Operating System CD with you all of you have to do is to make sure that the CD is set to 1st boot in your BIOS settings. Put your Windows XP CD in your optical drive and restart the computer. Watch the screen until you see the "Press any key to boot from cd.." if you see that press any key and it'll boot to the XP setup, wait for it to load and follow the instructions carefully.
some useful links
http://www.windowsreinstall.com/winxppro/indexinstallguides.htm
http://www.windowsreinstall.com/winxppro/sp2sp3installxpcdnewhdd/indexfullpage.htm
Note: You cannot downgrade Vista to XP without doing a clean install, the instruction above is a clean install, meaning everything in your hard drive will be deleted.
Jan 08, 2010 | Red Hat for Linux
DVD Drive reads CD's but wont read any DVD's
Let me explain some things for you to understand what happened with the dvd drive.
A laptop (or desktop) dvd writter drive is actually build around 2 separate optical systems each specialised to deal with either a cd or a dvd type of disk.
A cd has normally around 650mb - 700mb.
A dvd has normally around 4,3gb - 4,7 gb.
But both disks have the sime size. So the larger capacity disk, the dvd has higher data density as related to the disk surface. Therefore because these disks are being read using laser diodes, each diode must be tuned to a specific frequency for each type of disk. A cd is read/written by a 860 nm diode (infrared) and a dvd is read written by a 630 nm diode (red). These are separate optic subcomponents (by the way, a blue ray disk and reader is called blue ray because of the diode that is used to read them, it's on 437nm and it's emitting blue light).
If your drive will read only cd's and fail to read a dvd then it means that the coresponding optic block for dvd reading has failed. The cd optic system will continue to function as it's not linked to the dvd part.
In this situations there is little to do to save your drive so you should consider the replacement or assistance in a service center for your problem. I'm sorry as we aren't able to fix this without having to dissasemble things and use some service equipment.
May 22, 2009 | HP Compaq nx8220 Notebook
update 4090 xcdt
Yes, you can upgrade from Win98 to WinXP. The minimum hard drive requirements for WinXP is 1.5GB and the minimum RAM requirement is 64MB. You will also need a CD ROM for the install. Now those are the minimum requirements so don't expect it to go very fast. If possible I would recommend you upgrade to Win2000. WinXP and Win2000 are almost identical. The minimum hard drive for Win2000 is 650MB and for RAM it is 64MB. So you could still use your 4GB hard drive and have plenty of room. You will need a CD ROM for the Win2000 also.
Good luck if you have anymore questons let me know,
Don't forget to rate this solution before you log off.
Jan 19, 2009 | Toshiba Satellite 4090XDVD Notebook
762 people viewed this tip
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
