Tip & How-To about Video Game Consoles & Games
How to correctly setup an R4i card version 1.4 (red box)
First, take everything out of the packaging. Turn you computer on and go to your desktop. Then take you MicroSD card out and connect it to/ insert it in the T-flash (the USB port connector), and plug that into you USB port. Wait for the "what do you want to do?" menu to load and click "open folder to view files. After that, go to http://www.ishopvideogame.com/r4i-for-dsi-cid-167.html. Search for your version and download the latest kernel version. ( the kernels are wat say "r4i version 1.4," and etc.) Once you have downladed it, if you do not have an extractor/unzip program go to http://rarlab.com/download.htm and download winrar for you computer. If you already have an unzip/extractor program, use it on the kernel file you just downloaded. You will see a new file appear with the same name. Open the file and drag your mouse over all of the folder's contents, then right click and select 'copy' then paste them into your MicroSD card folder. Thats all you need to do, and for roms you just copy and paste them into the MicroSd card folder. i would suggest making a members account on Romulation.net, a great downloading place for roms.
Video Game Consoles & Games Logo
my memory card as been locked it is not opening and asking the password
Micro Secure Digital memory cards, or Micro SD cards, provide storage for a variety of different kinds of devices, including mobile phones, PDAs and cameras.
They can be protected by passwords so that the information that you have saved on it is secure. Sometimes, the password can be forgotten or lost.
Recovering your password is easily done with your computer and SD card reader on your computer.
Place the micro SD card into your card reader on your computer.
Right-click your "Start" button and then "Explore".
Find the micro SD card, it will be listed as a removable drive.
Click on the micro SD card and the files will show on the right-hand side.
Find the file that says " MMCSTORE" and then select "Copy."
Right-click on your desktop and then click "Paste."
This will move the MMCSTORE file to the desktop so that you can get access to edit it.
Right-click on the MMCSTORE and then click on "Open With." Open the file with Notepad.
Read the text to find the password. It will be in plain text.
Remove the SD card from the computer and place it into the device for which it is used as storage. Turn on the device.
When it prompts you for the password, enter it.
or
Delete a MicroSD Card Password
Some MicroSD cards are password protected, preventing you from using the card without the password.
You can circumvent this restriction by formatting the card, which eliminates the password requirement.
Insert the MicroSD card in your MicroSD card adapter and insert the adapter in the SD slot on your computer.
Right-click "Start" and select "Explore".
Click "Computer" and right-click the drive letter of the MicroSD card.
Select "Format", select the "FAT32" file system from the drop-down menu and press "Enter" to reformat the card.
Jan 24, 2012 | Kingston 1 GB microSD Card with USB 20...
how to get a 8gb microSD high capacity memory card to work on lg rumor 2
Try out your microSD, then connect to a computer with a card reader. If the computer can not detect, it is possible microSD damaged, but if the computer can detect but error, microSD can still be repaired.
Solutions to fix microSD, you can contacted me via Fixya Marketplace
Nov 25, 2011 | SanDisk Electronics - Others
where do I insert my microSD memory card or does my computer have a slot for it?
Here are the ways for you to insert your microSD to your computer
1. Use "memory card reader" (this is probably the best way)
find the slot that says "micro sd" that's where youre going to insert the microSD
2. Use the internal memory card reader of your pc ( if your computer has it)
it is located in front of your desktop. The find the slot that says "micro sd" and insert it.
Sep 13, 2011 | SanDisk 2GB microSD Memory Card
i bought a new microSD 2GB memory card and i want to insert it on the pc .i dont know where to insert it .give me a solution to it.
if you're using a laptop, it probable has a slot for a memory card. so just insert your micro SD adapter that usually comes with it when you buy it to be able to use it in your laptop.
if you're using a desktop, you can buy a card reader from any future shop or tech shops near you so you can connect it to your desktop.
Jan 26, 2011 | SanDisk 2GB microSD Memory Card
How do I transfer information from my lg vantage (ie: pictures) via USB connection to my home desktop pc?
By default, all of the pictures you take with the camera on the phone get saved to the microSD card inserted in the slot. There are two ways you can get the photos (and other data) off the card.
1. Using the USB cable that came with the phone, plug it in your computer. Then, tap the main menu, go to settings (the last tab) and then click 'USB Mode'. There, click USB Mass Storage, and your microSD card will be read by your computer.
2. Remove the microSD card (taking off the back panel and pushing down on the microSD card gently; the card will spring out). Insert the card in a card reader and voila. :)
You can then transfer photos to and from your phone (well... actually memory card :P)
Apr 18, 2009 | Cell Phones
685 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
