Tip & How-To about Computers & Internet
How To Block Spam and Advertising With Firefox
If your on a limited internet connection like me or simply need to have your browsing speed boosted , blocking ads on web pages is really easy to do and works great.
This tutorial is only applicable for Mozilla Firefox users. GET FIREFOX HERE
Okay , so start up your Firefox and select "Tools" from the top options.
Now select Add-ons.
This will take you to the add-on screen at which point you need to select "Get Add-ons"
Once there , type "ad blocker" in the search bar and search. Then select ad blocker from the search results.
Now click on the "add to Firefox" button in the right corner and the plug in will install. You may get window asking you to confirm that you wish to install the plug in to which you select install.
The program will now install and you will need to restart Firefox after this has completed.
This program will now block most ads on web pages. To disable or uninstall it later , go back to tools > add-ons> and click disable or uninstall under ad blocker.
Here is a video for an alternative method to install ad blocker if you are having problems. CLICK HERE
Here is ad-blocker's site , CLICK HERE
If you have found this information to be helpful , please rate the solution.
Kind Regards
Computers & Internet Logo
Where to find the Cloud on my Galaxy J3?
Install the free Ad-block Browser
  • An alternative to your current browser is the free Ad-block Browser, made by the same company as the notorious AdBlock desktop extension.
    Block pop-up ads in ChromeIf it's really only the pop-up adverts that bother you and you'd rather not have to install a second browser then these can be blocked in Google's own Chrome browser. Launch the browser, tap on the three dots at the top right of the screen, then choose Settings, Site Settings.
    Scroll down to Pop-ups and ensure the slider is set to Blocked.
    Use Data Saver mode If you are sticking Chrome, there is another step you can take to avoid data-hogging content online.
    Data Saver compresses aspects of web pages that aren't required on mobile devices. It offers a smoother web browsing experience, and savings on your data bill as your phone no longer struggles to pull down unnecessary ads and animations.
    It can lead to a somewhat flatter browsing experience, and it is possible that some web pages will look wonky. But you can always disable Data Saver - it's a two-second job.
    Open up Chrome, and then hit the three dots menu icon in the top righthand corner. Choose Settings, then find Data Saver. Ensure this is set to On.
Dec 07, 2017 | Galaxy Computers & Internet
I am using Linksys Wireless- N (wrt120) and my download speed seems to work great but when I browse the internet my pages won't load. Sometimes they will load very slowly. It seems like the connection
There may be competing wireless routers or networks nearby on the same band. Within the router's interface, try switching to a different band (2.4 Ghz vs. 5.0 Ghz) or use different radio channels. By default the router will attempt to do this automatically, but you may want to try adjusting them yourself and see what you get.
Oct 24, 2017 | Cisco - Linksys Wireless-n Home Router -...
Some sites the scroll down speed is really slow. It seems like text pages are ok and ones with images really slows the scroll responce down. Any ideas??? Thanks!!
Sounds like you are having problems with your Internet connection speed.You could try some of these tips..
  • Step 1 Click Start > Control Panel > Network and Internet Connections.
    Select "Internet Options."
    Under Check for newer versions of stored pages, click "Automatically." Under browsing history, click "Settings."
    If you're using dial-up, set the number under Disk Space to Use to between 250 and 1024 megabytes (MB). If you're using a DSL or cable connection, set it between 50 and 75 MB. Click "OK."
  • Step 2 Select "Delete" under Browsing history.
    Click "Delete files..." under Temporary Internet Files to clear your browser cache.
    Click "Delete cookies..." to remove all cookies from your hard drive.
  • Step 3 Disable any browser add-ons you don't need. In Internet Options, click "Programs." Click "Add-ons currently loaded in Internet Explorer." Select the name of the add-on you don't want to load, and select "Disable" under Settings at the bottom of the dialogue box. Avoid deleting ActiveX controls as this will most likely cause the browser to prompt you each time you encounter content on the web, such as Flash animations, that use that control.
  • Step 4 Switch to a faster browser. While Internet Explorer is the most popular browser, it often causes pages to load slowly. Download a free browser such as Firefox, Opera or Chrome to get a quick speed boost to your browsing.
  • Step 5 Disable images in your browser. To disable images in Internet Explorer, open Internet Options and click the "Advanced" tab. Scroll down to "Multimedia" and uncheck "Show Pictures."
    To disable them in Firefox, click Tools > Options in your browser window and select "Content." Uncheck the box beside "Load images automatically."
    To disable images in Opera, open the arrow beside the camera icon at the bottom of your browser, and select "No images."
    To browse with Google Chrome without images, right click on the Chrome shortcut and place the switch "-disable-images" without quotes after the last quotation mark in the path of the file.
  • Step 6 Disable active content if you're still experiencing a problem with your browsing speed. Return to the "Advanced" tab in Internet Options. Uncheck the boxes beside "Play animations in webpages" and "Play sounds in webpages."
  • Aug 11, 2010 | Dell SP2309W 23-Inch LCD Widescreen...
    1,575 people viewed this tip
    David Payne
    David Payne
