Tip & How-To about Video Game Consoles & Games
If your Xbox 360 Disc tray won't eject
If your Xbox 360 DVD drive won’t eject it can be a very simple fix.
The Samsung drive is almost always a very simple fix, if you have another drive, it may be more difficult.
To identify your drive, follow this guide:
• Remove the faceplate by firmly grasping the opening for the USB ports and pulling.
• Underneath the DVD tray there should be a small hole.
• Look at the wires in the hole to identify which drive type you have.
Red and Black Wires = Samsung Drive
Yellow Wires = LiteOn Drive
White Wires = BenQ Drive
No Wires = Hitachi Drive
SAMSUNG:
It is very common for a Samsung drive to not eject. It’s a very simple fix for this!
1. Power on your Xbox 360
2. Press the eject button
3. When the Xbox 360 “tries” to eject, just simply push in on the tray cover.
That should make it eject!
If it does not, please follow the guide for the other drives below:
This requires you to disassemble your Xbox 360. IF you don’t know how, look it up on google, there are plenty of guides.
Then follow these steps:
1. Remove your Xbox 360 DVD drive from the Xbox 360
2. Turn over and remove the four screws securing the drive (6 screws if it’s a Hitachi)
3. Remove the top cover of the DVD drive.
4. Put the drive back in the Xbox 360, connect the wires, and power on your Xbox 360.
5. Once the 360 powers on, eject the drive. Most of the time it should eject normally. If it doesn’t you may have to force it.
6. Unplug the Xbox 360. If you turn it off with the power button the tray will close first, we need it open.
7. Near the front of the drive, you should now be able to see and access a small rubber band that was hidden by the tray.
8. Remove the band, lubricate and replace.
9. Replace the top cover and hook up and test.
10. If that doesn’t work, you may need a new rubber band. If you can get one of the right size, replace and test.
Video Game Consoles & Games Logo
everytime i put a disc in my xbox it reads dvd. I got to keep ejecting it and closing it back to make it read the game . Pleasee!!!!!!!!!!!!!!! help me
Just to make certain it's not a burnt game on a modded/flashed xbox then more likely your optical dvd drive on the DVD player for the xbox 360 is going out. The lens and laser can be acting up inside and the only way to fix this is to replace the optical dvd drive. You can remove the optical drive and it has 4 screws. You carefully remove the chip inside and transfer to new xbox 360 optical drive which by the way has to be the exact same model to work properly. There are detailed instructions on youtube on how to remove and replace a xbox 360 dvd player.
Dec 22, 2010 | Microsoft Xbox 360 Console
what can i do when the tray of my xbox 360 does not want to open?
This is a common problem for the Xbox 360 and s usually caused by the dvd drive belt becoming old and weak. Try putting the xbox 360 horizontally and when you press the eject button press the drive slot and rub it upwards. This will help the belt to turn the eject mechanism and hopefully should eject for you.
Hope this helps
Nov 24, 2010 | Microsoft Xbox 360 Console
dvd drive is not responding on 360
the ROM drive has failed. you will have to install a new drive or repair the components within this ROM.
Mar 10, 2009 | Microsoft Xbox 360 Console
My xbox 360 keeps on restarting by itself
lol girl and boys easy the way i fix may xbox.
trun on my xbox then at the xboxdashboard go to the far reght and then go dowb to the very bottom of the page then rest ur xbox again done.
tys for time
Mar 18, 2008 | Microsoft Xbox 360 Console
3,729 people viewed this tip
Top Video Game Consoles & Games Experts
Nikki  Mclean
Nikki Mclean
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
