Tip & How-To about Disney 's Learning Toddler Pooh and Mickey Win/Mac (2588701) for Mac, PC
Winnie the Pooh Learning Toddler
This is for the Pooh Learning Toddler that came with the 2 disc bundle, running on a Windows XP operating system.
The software installed fine, but it was crashing when trying to open from the built-in "Launcher." I believe the error was Macromedia Projector related. Instead of opening with the Launcher.exe, open the WinnieT.exe program. You'll probably have to create a separate shortcut to your desktop/Start Menu, if you want a shortcut, that is. Before you open the program, some small adjustments need to be made. Right click on WinnieT.exe. Go to the Properties, then the Compatibility menu. Change the Compatibility mode to Windows 95 and check all the boxes below (I think the 640x480 resolution and the 256 colors is especially important to check). I believe it also ran for me in the Windows 98/ME mode, but there is no difference between the two. Good luck!
Disney 's Learning Toddler Pooh and Mickey Win/Mac (2588701) for Mac, PC Logo
I have windows 7 and when i tried to install Oregon trail 5th edition on my computer, it said wasn't compatible and that the disk was never located.
right click on the setup file select properties then the compatibility tab set the compatibility to windows xp sp2 and check the run as administrator box. The setup file will be somewhere on the disc and will be a .exe or .msi
May 11, 2011 | The Learning Company Oregon Trail 5th...
i purchased the mysterious adventures bundle. 16 complete games. it will not install on my windows 7
Go to the web site and find the game and it's description.
There should be a section describing system requirements. See if Win7 is listed/supported.
You can also try these two other options (may or may not help).
1) Try Running the install as Administrator
Right click on the file you want to run (install) and select "Run as Administrator"
2) If it is older software, try running/installing the software in in XP Compatibility Mode
To read about XP compatibility mode:
Go to start menu
Select Help and Support
Type xp compatibility in the search window
Select #2, Make older programs run in this verison of windows
There are instructions on how run the install using compatibility mode.
Mar 18, 2011 | ValuSoft Computers & Internet
how install window xp & how to connect data card or setup for internet
To install Windows XP you first need a bootable Windows XP Disc or an ISO image. Using that you can boot your windows and install the operating system.
Once you get your bootable Disc or boot from the disc and follow the onscreen instructions to install the windows xp operating system. Make sure that you have all the data of yours backed up and you have a geniune windows xp product key.
once your operating system is intalled, connect the data card and insert the cd that came along with the datacard to install the drivers and the software. incase you did not get a cd, or you dont have one, please visit the site of the datacard manufacturer and download an appropriate drivers and software and install them. This should get your data card up and running.
Thanks and please remember to rate and leave a testimonial if you find the solution useful.
Feb 22, 2011 | Cell Phones
Windows Update puts install software on D: drive
You want to disc clean up by going start menu ,all programmes, accessories,system tools , and disc clean up.
Nov 04, 2009 | Microsoft Windows XP Professional
I CAN'T INSTALL A WINDOWS XP SOFTWARE
Thank you for choosing Fixya.com
Yes you can install the Windows XP on P4X266.
Here could be five various steps you can go about.
  • Method 1: Perform a clean install of Windows XP
    Use this method for a clean installation of Windows XP. A clean installation removes all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk.
  • Method 2: Upgrade to Windows XP
    Use this method if you are upgrading to Windows XP from Microsoft Windows 98, Microsoft Windows Millennium Edition, or Microsoft Windows 2000 Professional.
  • Method 3: Install Windows XP to a new hard disk
    Use this method to install Windows XP to a new hard disk. This is typically done when a new hard disk is installed on your computer.
  • Method 4: Install Windows XP to a new folder (parallel installation)
    Use this method to install Windows XP to a new folder (parallel installation) to either run two operating systems, or to access, repair, or retrieve data from a damaged disk.
  • Method 5: Perform a multiple boot operation
    Use this method to install Windows XP as a separate operating system on your computer. This lets you install more than one operating system on your computer and select which operating system that you want to use every time that you start your computer.
To check the detailed information, check this Microsoft Knowledge Base Article.
http://support.microsoft.com/kb/316941
Hope this would help !!
Regard's
Anurag Shukla
Sep 08, 2009 | VIA P4X266 PE11-L Motherboard
485 people viewed this tip
Top Disney Computers & Internet Experts
Jax Planet
Jax Planet
ray gallant
Are you a Disney Computer and Internet Expert? Answer questions, earn points and help others
