Tip & How-To about Computers & Internet
Remove Recycle Bin from Desktop- XP
Go to START > RUN
Type GPEDIT.MSC
Navagate to USER CONFIGURATION >ADMINISTRATIVE TEMPLATES >Click onDESKTOP,
On the right hand pane find " Remove Recycle Bin icon on the desktop " , double left click on it to ENABLE it.
Computers & Internet Logo
how to remove recycle bin from hp mini desktop
How to remove Recycle Bin Icon from Desktop
If using XP Pro
Go to START > RUN
Type GPEDIT.MSC
Navagate to USER CONFIGURATION >ADMINISTRATIVE TEMPLATES >Click on DESKTOP,
If using XP Home
Either use TweakUI or make the change manually in the registry.
Create or modify the following registry entry
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel
{645FF040-5081-101B-9F08-00AA002F954E}
REG_DWORD
0x00000001
Vista or Win7
Start> control panel > Personalization > on the left hand side choose "change desktop icons" and uncheck recycle bin and hit ok.
Mar 09, 2011 | Computers & Internet
how to enable control panael,taskmanager
Method 1 - Using the Group Policy Editor in Windows XP Professional
  1. Click Start, Run, type gpedit.msc and click OK.
  2. Under User Configuration, Click on the plus (+) next to Administrative Templates
  3. Click on the plus (+) next tSystem, then click on Ctrl+Alt+Delete Options
  4. Find Remove Task Manager in the right-hand pane and double click on it
  5. Choose the option "Not Configured" and click Ok.
  6. Close the Group Policy Window
Method 2: Change the Task Manager Option through the Run line
  1. Click on Start, Run and type the following command exactly and press Enter
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /v DisableTaskMgr /t REG_DWORD /d 0 /f
Method 3: Change Task Manager through a Registry REG file
  1. Click on Start, Run, and type Notepad and press Enter
  2. Copy and paste the information between the dotted lines into Notepad and save it to your desktop as taskmanager.reg
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
3. Double click on the taskmanager.reg file to enter the information into the Windows registry
Method 4: Delete the restriction in the registry manually
  1. Click on Start, Run, and type REGEDIT and press Enter
  2. Navigate to the following branch
    HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System
  3. In the right pane, find and delete the value named DisableTaskMgr
  4. Close the registry editor
For Control Panel
Start | Run | Type: gpedit.msc | OK |
Navigate to >>>
User Configuration\Administrative Templates\Control Panel\
Prohibit access to the Control Panel
[[Disables all Control Panel programs.]]
Jan 12, 2010 | Microsoft Windows XP Home Edition
my system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
For standalone Windows Vista systems, use these steps:
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
the recycle bin icon is gone
Right click on your desktop, select "Personalize", click on "Change deskop icons" from the left pane. and check Recycle Bin or
  1. Goto Start->Run and type in Gpedit.msc and press enter.
  2. Navagate to USER CONFIGURATION >ADMINISTRATIVE TEMPLATES >Click on DESKTOP.
  3. On the right hand pane find ” Remove Recycle Bin icon on the desktop ” , double left click on it to disable it.
Jun 26, 2009 | HP Compaq Presario CQ50-110US Laptop
170 people viewed this tip
David Payne
David Payne
