Tip & How-To about Office Equipment & Supplies
How Can I Make My Old Printer Cartridges Work .
Step 1: Remove the cartridge from the computer
Step 2: Soak the tip of the catridge in a luke warm water / If some ink runs in the water, it means that the holes have been unblocked.
Note: I would suggest you to do an automatic head cleaning each time before any printing task. Hence it will reduce the risk of having the print heads blocked by dried ink.
Step 3: Or with the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
Step 4: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
prints blank pages, if cartridge is removed it fixes it for a while, then problem occurs again.
In this case what i would request u to do is.......
Take out both the catridges from the Printer.........
Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds......
Now remove it and see whether u see any ink on the paper towel..........
U should see some ink on it now place the dry paper towel on the ink catridge in the same way........
Now do the same procedure again..........
Do the same procedure twice on the Black Catridge.................
Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel..........
Know insert both the catridges inside the Printer........
Good Luck
Apr 05, 2009 | Brother MFC 240C All-In-One InkJet Printer
i960 won't print despite new print head
Hello!!
Switch off the printer and disconect the USB cable for 30 seconds. deep clean on the black head to get it work properly.
Feb 08, 2008 | Canon I960 InkJet Photo Printer
dell 964 printer reads color but not black cartridge
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer...... Now try to Print it will work Fine......................
Feb 14, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
my canon multipass 730 indicates wrong cartridge
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer.................. Now turn on the Printer and chk......... Good Luck
Jan 21, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MP730 Print Head needs a manual clean
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer........... You can do the same procedure i don think there is a need of a separate cleaner for that......... Thanku
Jan 20, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
245 people viewed this tip
jasbo
jasbo
