Tip & How-To about Computers & Internet
Bit Torrent Tutorial
The first things you need to know about using Bit Torrent: -- Bit Torrent is aimed at broadband users (or any connection better than dialup).
-- Sharing is highly appreciated, and sharing is what keeps bit torrent alive.
-- A bit torrent file (*.torrent) contains information about the piece structure of the download (more on this later)
-- The method of downloading is not your conventional type of download. Since downloads do not come in as one big chunk, you are able to download from many people at once, increasing your download speeds. There may be 100 "pieces" to a file, or 20,000+ pieces, all depending on what you're downloading. Pieces are usually small (under 200kb)
-- The speeds are based upon people sharing as they download, and seeders. Seeders are people who constantly share in order to keep torrents alive. Usually seeders are on fast connections (10mb or higher).
In this tutorial, I will be describing it all using a bit torrent client called Azureus. This client is used to decode the .torrent files into a useable format to download from other peers. From here on out, I will refer to Bit Torrent as BT.
Which BT client you use, is purely up to you. I have tried them all, and my personal favorite is Azureus for many reasons. A big problem with most BT clients out there is that they are extremely CPU intensive, usually using 100% of your cpu power during the whole process. This is the number one reason I use Azureus. Another, is a recently released plug-in that enables you to browse all current files listed on supernova.org (the #1 source for torrent downloads).
Before you use the plug-in, take a look at http://www.suprnova.org, and browse the files. Hold your mouse over the links, and you'll notice every file ends in .torrent. This is the BT file extension. Usually, .torrent files are very small, under 200kb. They contain a wealth of information about the file you want to download. A .torrent file can contain just 1 single file, or a directory full of files and more directories. But regardless, every download is split up into hundreds or thousands of pieces. The pieces make it much easier to download at higher speeds. Back to suprnova.org. Look at the columns:
Added | Name | File size | Seeds | DLs (and a few more which aren't very useful.)
I'll break this down.
Added: Self explanatory, it’s the date the torrent was added.
Name: Also self explanatory.
File size: Duh
Seeds: This is how many people is strictly UPLOADING, or sharing. These people are the ones that keep .torrent files alive. By "alive", I mean, if there's no one sharing the .torrent file, no one can download.
DLs: This is how many people currently downloading that particular torrent. They also help keep the torrent alive as they share while they download.
It's always best to download using a torrent that has a decent amount of seeders and downloaders, this way you can be assured there's a good chance your download will finish. The more the better.
Now that you should understand how torrent files work, and how to use them, on to Azureus!
First, get JAVA! You need this to run Azureus, as java is what powers it. Get Java here: /http://java.sun.com/j2se/1.4.2/download.html
Next, get Azureus at: /http://azureus.sourceforge.net
Next, get the Supernova lister plugin from http://s93732957.onlinehome.us/storage/supernovalister.jar
Install Java JRE before you do ANYTHING.
Install Azureus, and then in the installation folder, create 2 more folders. ./Plugins/suprnovalister (For example, if you installed Azureus to C:\PROGRAM FILES\AZUREUS, create C:\PROGRAM FILES\AZUREUS\PLUGINS\SUPRNOVALISTER). Next, put the suprnovalister.jar file that you downloaded, in that folder.
Load up Azureus, and if you want, go through the settings and personalize it.
The tab labeled "My Torrents" is the section of Azureus you need the most often. That lists all your transfers, uploads and downloads. It shows every bit of information you could possibly want to know about torrents you download.
In the menu bar, go to View > Plugins > Suprnova Lister. This will open up a new tab in Azureus. Click on "Update Mirror". This will get a mirror site of suprnova.org containing all current torrent files available. Once a mirror is grabbed, choose a category from the drop-down box to the left and click "Update". Wah-lah, all the available downloads appear in the main chart above. Just double click a download you want, and bang its starting to download. Open the "My Torrents" tab again to view and make sure your download started.
After your download has finished, be nice, and leave the torrent transferring. So people can get pieces of the file from you, just as you got pieces from other people.
Alternatively, if you don't want to use the plugin... you can just head to suprnova.org and download files to any folder. Then go to File > Open > .torrent File in Azureus.
This should about wrap it up for the Bit Torrent Tutorial. If you guys think of anything I should add, or what not, just let me know and I'll check into it.
Computers & Internet Logo
Hangs with Bittorrent
That is because you need to open a port on router with the same number assigned to your torrent client.
You need to check port number on bittorrent configuration, then access router control panel typing router IP on internet explorer address bar and configure the router to open the port.
Read the following articles.
How to configure your router to allow fast BitTorrent downloads
Brian's BitTorrent FAQ and Guide: What ports does BitTorrent use
Slow Bit Torrent downloads? Router configuration tips.
Opening port BitTorrent |
forum.bittorrent.com / how to open firewall/router port
Guide to Open or Forward Ports for Utorrent and Azureus BitTorrent
Port Forwarding for the Netgear WGR614
Tweaking your system to get the most out of BitTorrent
Apr 13, 2009 | Computers & Internet
internet connction problm due 2proxy ser er
  1. Get Azureus from azureus.sourceforge.net. (You need to have Java installed on your machine first.)
  2. Run and configure Azureus:
    • Skip any updates, because they rely on torrents.
    • Set your proficiency level to Intermediate, so you can change the encryption settings later.
  3. Go to Tools -> Options -> Connections -> Transport Encryption, and require encryption.
  4. Under Mode, set your proficiency to Beginner. (Beginner has all the options you'll ever need as a downloader.)
  5. Restart Azureus, and let it do any updates it deems necessary.
Jan 29, 2009 | Computers & Internet
i can't find the number on the jewel case to start downloading my age of empires game......
I cant help you with the key code, but as you have bought the game (I asume), I se no problem downloading this version with key and crack from:
http://thepiratebay.org/torrent/3815854/Age_of_Empires_III___Warchiefs_Expansion_(Complete_Working)
You need a program to "open" the torrent with, an I know some use Vuze, you'll find that here:
http://azureus.sourceforge.net/
Good luck
/Teis
Dec 01, 2008 | Computers & Internet
About KPT plugin
Dear manhole,
You can download following torrent for having complete collection of KPT plugins:
http://www.mininova.org/tor/33795
You will require a client program to download this torrent. Please download one of these clients
a) azureus
b) bittorrent
c) utorrent
Nov 20, 2007 | Adobe Photoshop 7.0 for PC
335 people viewed this tip
David Payne
David Payne
