Tip & How-To about Cell Phones
Unlocking code for samsung j600/j700 mobiles
Please follow the instructions carefully but if the code fails to work, then ,make no more than 4 attempts as it may lock your phone. Can you let me know how you get on with it as well please. Thanks. Please also make sure that you back up any information on your phone as in certain cases the resetting also removes your contacts from the SIM and your pictures. j700/j600 unlock method Basically the SP lock needs to be removed before the Network lock is disabled, so if you only have SP lock on, you need to turn the Network lock back to active, disable the SP lock and then disable Network lock. A reminder 'how to' is below: Do a custom reset: *2767*2878# once this has finished rebooting turn the phone off. Next a SIM card from a different service provider needs to be pushed half in - (Push it fully in then slide it back out by about 1/2 a centimeter), Turn on the phone - you will now see an "Insert SIM" message, Now perform a full reset: *2767*3855# When the phone powers off, quickly push the SIM card fully in, and let the phone power back up. After you do the reset, check and make sure that your Network lock is active by pressing *#7465625# If it isn't active you must use this code to reactivate it: *7465625*638*00000000*00000000# Then you have to deactivate the SP lock first. To do that you need to input: *7465625*77*00000000*00000000# (this will reset the lock) Then you enter: #7465625*77*00000000# (to disable the SP lock). Then you disable the Network lock: #7465625*638*00000000#
Cell Phones Logo
my china mobile IMEI:-35269500557980 and when sim is putting it was say invalid sim pls tell solution sir
Please follow the instructions carefully but if the code fails to work, then ,make no more than 4 attempts as it may lock your phone. Can you let me know how you get on with it as well please. Thanks. Please also make sure that you back up any information on your phone as in certain cases the resetting also removes your contacts from the SIM and your pictures. j700 unlock method Basically the SP lock needs to be removed before the Network lock is disabled, so if you only have SP lock on, you need to turn the Network lock back to active, disable the SP lock and then disable Network lock. A reminder 'how to' is below: Do a custom reset: *2767*2878# once this has finished rebooting turn the phone off. Next a SIM card from a different service provider needs to be pushed half in - (Push it fully in then slide it back out by about 1/2 a centimeter), Turn on the phone - you will now see an "Insert SIM" message, Now perform a full reset: *2767*3855# When the phone powers off, quickly push the SIM card fully in, and let the phone power back up. After you do the reset, check and make sure that your Network lock is active by pressing *#7465625# If it isn't active you must use this code to reactivate it: *7465625*638*00000000*00000000# Then you have to deactivate the SP lock first. To do that you need to input: *7465625*77*00000000*00000000# (this will reset the lock) Then you enter: #7465625*77*00000000# (to disable the SP lock). Then you disable the Network lock: #7465625*638*00000000#
Feb 02, 2010 | Cell Phones
i need to unlock a samsung j600 phone please, or at least do something that would let me use an orange sim card in it instead of o2...
Sir, I think you mean the network is locked. In that case, you have to contact O2 to unlock your mobile from their network. This way you will get any sim to work on your mobile.
Thank you Sir, Have a nice day.
Sep 24, 2009 | Samsung SGH-J600 Cellular Phone
i forgot password on samsung sgh j210.. it as
Mar 28, 2009 | Samsung SGH-J600 Cellular Phone
Samsung SGH-J600
how can i unlock my samsung sgh-j600 phone for free
Sep 24, 2008 | Samsung SGH-J600 Cellular Phone
phone lock samsung j600
Please follow the instructions carefully but if the code fails to work, then ,make no more than 4 attempts as it may lock your phone. Can you let me know how you get on with it as well please. Thanks. Please also make sure that you back up any information on your phone as in certain cases the resetting also removes your contacts from the SIM and your pictures. Basically the SP lock needs to be removed before the Network lock is disabled, so if you only have SP lock on, you need to turn the Network lock back to active, disable the SP lock and then disable Network lock. A reminder 'how to' is below: Do a custom reset: *2767*2878# once this has finished rebooting turn the phone off. Next a SIM card from a different service provider needs to be pushed half in - (Push it fully in then slide it back out by about 1/2 a centimeter), Turn on the phone - you will now see an "Insert SIM" message, Now perform a full reset: *2767*3855# When the phone powers off, quickly push the SIM card fully in, and let the phone power back up. After you do the reset, check and make sure that your Network lock is active by pressing *#7465625# If it isn't active you must use this code to reactivate it: *7465625*638*00000000*00000000# Then you have to deactivate the SP lock first. To do that you need to input: *7465625*77*00000000*00000000# (this will reset the lock) Then you enter: #7465625*77*00000000# (to disable the SP lock). Then you disable the Network lock: #7465625*638*00000000#
Dec 14, 2007 | Cell Phones
191 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
