Tip & How-To about Computers & Internet
How to Fix Windows Installer problems...
Do you experience this kind of problem whenever you attempt to install an application in windows box (2K, XP, etc.)?
"The Windows Installer service could not be accessed. This can occur if you are running Windows in Safe Mode, or if the Windows Installer is not correctly installed. Contact your support personnel for assistance."
The ms website knowledge article 324516 gives 2 methods as a way of fixing this problem, but you might be very lucky if any of the 2 fixes the problem, a lot of guys end up formatting their systems and doing fresh windows installations or try wired ways of fixing it.
Well, the solution is very easy:
1) Right click your root windows installation drive i.e. drive where you installed windows
2) Click properties at the bottom
3) Select Security tab
4) Click Add and scroll down to SYSTEM account click add and click OK.
5) Allow Full control permission and click Apply and then OK.
This should solve your problem with windows installer.
Computers & Internet Logo
Re-register Windows Installer Service in xp
Method 1: Use the Msconfig tool to confirm that the installer service is running
  1. Click Start, and then click Run. ...
  2. In the Open box, type msconfig, and then click OK. ...
  3. On the Services tab, click to select the check box that is next to Windows Installer . ...
  4. Click OK, and then click Restart to restart the computer.
More items...
"The Windows Installer service could not be accessed" error message ...
https://support.microsoft.com/en-gb/kb/324516 https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=Re-register+Windows+Installer+Service+in+xp
Nov 24, 2016 | Computers & Internet
why will printmaster platinum 2.0 not uninstall
Try using the Windows Installermag-glass_10x10.gif CleanUp Utility. As long as you installed the application using the Windows Installer, this utility will remove all the folders, files, registry keys, and entries from your system and allow you to start over with a clean slate.
Download the Windows Installer CleanUp Utility
Locate and run msicuu2.exe to install the Windows Installer CleanUp Utility.
Locate and launch the Windows Installer CleanUp Utility on the Start menu.
From the Windows Installer CleanUp Utility window, locate the application in the list and click the Remove button.
Once the application has been removed, click the Exit button to close the utility.
You may now reinstall the application or at least have piece of mind that it is gone
This version of the Windows Installer CleanUp Utility works correctly in all 32-bit versions of Microsoft Windows. The 32-bit versions of Microsoft Windows are: :
Microsoft Windows Server 2003
Microsoft Windows XP
Microsoft Windows Millennium Edition
Microsoft Windows 2000
Microsoft Windows NT 4.0 with Service Pack 3 or later
Microsoft Windows 98
Microsoft Windows 95
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 17, 2010 | Broderbund PrintMaster Platinum 16
Windows Installer pops up everytime I open Access, Excel ..etc.
your applications didn't full instalations..try to reinstal n upgrade your software..
Apr 06, 2009 | Microsoft Office Professional 2007 Full...
My windows cannot open exefile and I cannot install spybotsd162.
Dear johan_poliwa, ur windows installer has corrupted or have been deleted. The best possible solution is that u format ur OS.
Mar 19, 2009 | Microsoft Windows Vista Home Basic Edition
Do you experience this kind of problem whenever you attemp to install an application in windows box (2k, xp)?
"The Windows Installer service could not be accessed. This can occur if you are running Windows in safe mode, or if the Windows Installer is not correctly installed. Contact your support personnel for assistance."
The ms website knowledge article 324516 gives 2 methods as a way of fixing this problem, but you might be very lucky if any of the 2 fixes the problem, alot of guys end up formating their systems and doing fresh windows installations or try wired ways of fixing it.
1. right click your root windows installation drive i.e drive where you installed windows 2. click properties at the bottom 3. select security tab 4. click Add and scroll down to SYSTEM account click add and click OK. 5. allow Full control permission and click Apply and then Ok.
Oct 19, 2008 | Computers & Internet
172 people viewed this tip
David Payne
David Payne
