Tip & How-To about Computers & Internet
How to Fix Computer
If you face any problem with your computer system you can either fix ityourself or get it fixed by a computer professional. You need to fixall the hardware and software related errors for proper functioning ofyour computer.
Hardware and software errors
The common problems faced with the computer hardware includes the harddrive failure, power supply failure, motherboard failure, CPU failure,video card failure, USB device failure, and many others. The commonproblem with software includes - programs refuses to install, programdoesn’t load or takes more time to load, software functioningimproperly, operating system failure, incompatible device drivers, andother related issues.
There can be a wide range of problems which might occur in your PC dueto several unseen and even unknown issues like your computer does notturn on, you see a disk error message when you log on to your systemand many others. If you are a Windows user then you can find the helpfor most of the common hardware and software related errors on yourcomputer itself. Microsoft Windows offers a help section mentioningsolution to some of the most common hardware and software relatedissues.
Windows "Help and Support" center
You can have a quick access to Windows help and support centre inWindows XP systems by clicking on the "Start" button followed byclicking on the "Help and Support" center. Similarly, you can alsoaccess the "Help and Support" centre in other versions of Windowsoperating system. The help center carries a database of the most commonproblems and solutions. After opening the help center you can type thesearch term in the search box to find the solution. It will display alist of results on the basis of the search query. It is yourresponsibility to find the best solution for the problem you are facing.
In case of system failure you can carry out some of these troubleshooting steps to solve this issue:
  • Check if your PC is plugged into a power source and it is switched on.
  • Reboot your PC to check if the problem still persists.
  • Restore your system to an earlier state.
  • Scan your PC hard drive for any errors.
  • Check for any memory problem.
  • Check for any device driver related issue.
  • Reinstall the operating system.
Finally if you are still unable to solve the issues then don’t proceedon making some irrecoverable changes, you can avail online help from atech support company who can solve your problems through remotecomputer repair service
Computers & Internet Logo
why is there no change after dounloading SparkTrust PC Cleaner Pluse?
I don't know anything about Spark Trust. I suggest that you get rid of all but one tool bar. Down load C Cleaner. Follow instructions and it will clean unused files and cookies and temporary files. It will also fix problems with your registry. My computer is seven years old and runs like new. Regular clean up will help your machine run faster.
Mar 20, 2013 | Computers & Internet
Attempts to install Garmin c330
there might be an problem with you street pilot, but try to download this software go to this webpage
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
that will keep your unitr up to date and fix any problems you might have with it
Dec 27, 2007 | Garmin StreetPilot C330 GPS Receiver
computer crashed and fix-it utilities 11 didn't reload fully. Need to enter product key and reinstall
I would recommend a top utility software, use intel partner software RegInOut to fix all your operating systems errors.
Dec 08, 2011 | Avanquest Fix-It Utilities 11 Professional...
lost c.d.need driver for iball c1.3 face to face webcam?
Hey John,
I have the driver of iball Face 2 Face C1.3 webcam. If u haven't got it as yet, email me at mandy_20@rediffmail.com. I will send the driver to you.
Regards
Mandy
There is nothing in a computer that cannot be fixed....
Jan 04, 2009 | Logitech Webcam
252 people viewed this tip
David Payne
David Payne
