Tip & How-To about Computers & Internet
Instaling operation system when a Sata Hdd is not seen
I will show a trick about how to install an operation system when you have an erased sata Hdd ..and cause of the lack of a raid driver it is blocking the boot and not let you boot even from cd ...
Insert the boot-able installation cd ...choose to boot first from cd ..and to trick the computer just remove the power supply from the Sata Hdd ...This way you will make it go on and boot from cd ...Keep in mind that the primary drivers and files that are loaded when the installation starts ..are not stored on the hdd..so it will not see the drive missing ...after it starts to load files...and before getting to the agreement ..just plug the supply back to the Hdd.. in this point the primary drivers will be already loaded ..and the computer it is already seeing the hard drive ...and will continue the installation like on any other one without any problems...
Good Luck !
Computers & Internet Logo
inspiron 531 wont boot up. just get dell screen then says Sata 0 Sata 1 Tsst corp DVD sata 2 None sata 3 None
If yo are sure that you have a working operating system on your hard disk , and this error started after you (probably) defaulted the Bios settings or something else did ....Than I think the lack of sata raid driver makes the reading of your hard disk impossible ..To fix this ..either try to reinstall the operation system and during it ..choose to add a 3rd party driver (look for raid driver on your motherboard cd ..or on the manufacturer's support site ) ..or ..just get into Bios again ..look for the HDD in the advanced options ..and select the hdd 0 ..and eliminate the achi feature ..and replace it with sata as ide ..or compatible ..and save settings with F10 and restart ..It will make the hdd visible ..and support installation if it has non ...or just boot up ..but will work as IDE and not raid ..
Aug 23, 2011 | Dell Inspiron 531s Desktop Computer
Windows can't install because it says it can't find a hard drive. Setup indicated both HD's are there and working. Installing Windows 2000 from Disc. Changed boot sequence so Rom boots first. Windows loads but when asked to install, it can't find HD on machine!Two Hard drives on machine. Both visible in set up and on diagnostic test
Check for sata drivers, if it is system is shipped with SATA hdd, need to install SATA Raid drivers during reinstallation .I believe that the dell system was originally shipped with Windows XP or Vista Operating system which has SATA drivers for SATA hdd. Since windows 2000 Operating system does not have SATA drivers hence unable to recognised hdd.
Aug 17, 2009 | Dell Dimension 9100 PC Desktop
installation problem of win98 in a sata hdd
try using third party raid driver and set bios to legacy device
May 08, 2009 | Microsoft Windows 98 for PC
sata hdd detected but problem with booting&installation
i have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration
Jun 30, 2008 | ASUS P5RD1-VM Motherboard
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
150 people viewed this tip
David Payne
David Payne
