Tip & How-To about Dryers
Dryer's Taking Too Long to Dry
One of the most common misconception's about dryers that are heating but taking way too long to dry is, oh no my dryer is broke, or something is wrong with my element.
This may sometimes be true in a sense, but usually not. A dryer depends on proper air flow to expel the warm, moist air from your clothes to the outside of your home. Most dryer exhaust problems are not at the dryer but from the wall to the outside.
The best and quickest and most fun way is to use an electric leaf blower to clear every thing in the exhaust line out, even water and critters that may find there way in. An inexpensive leaf blower from any major chain,Walmart, Kmart, Lowes or Home Depot will usually have fairly inexpensive ones.
Pull the dryer form the wall and disconnect the exhaust from the wall vent. Place the end of the blower inside the vent and turn it to the high setting. Now take an extension cord that is not plugged into the wall yet and connect to the blower. Push the dryer back against the blower so it will hold the blower in place. Now that you are set plug the other end into the electrical outlet and let it run for about 10 minutes. Go to the outside where the exhaust exits your home and watch all the stuff fly. The blower is blowing approx. 230 mph winds thru your entire exhaust which will also help clean the walls also of lint and debris build up. Do this once a year and you will save problems for your dryer, the life of the dryer and most important service problems that end up costing much more than the blower and 10 minutes of your time.
Good luck and thank you for reading and by the way, kids will love watching this too.
Dryers Logo
ied4400sq0 dryer is not drying - heats up a bit, fan works, tumbles, etc, just takes a million cycles to dry.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 13, 2011 | Dryers
My dryer isn't drying like it should. It doesn't seem as hot as it use to be and it takes forever to get things dry. I'm not sure if it's lint build up or something more. Any help will be appreciated.
heatman101';';
May 01, 2011 | Magic Chef CYG4000AWW Gas Dryer
dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
heating problem with stackable washer/dryer combo
check the duct work going out of the house if it is clogged the clothes wont dry. Birds love to build nest in a open dryer vent and if you have any bends lint will build up get these clean and it should get you drying again
let me know what you find
bill
Jan 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
252 people viewed this tip
Top Dryers Experts
