Tip & How-To about Video Game Consoles & Games
HOW TO CHANGE PSP THEME
TURN ON YOUR PSP. THEN GO TO SETTING IT SHOULD BE THE LAST ONE TO YOUR LEFT AND THEN SCROLL DOWN AND GO TO THEME SETTINGS. AFTER YOU DO THAT PRESS X THEN THE FIRST ONE SHOULD BE THEME PRESS X AGAIN IF YOU DOWNLOADED THEMES THEY SHOULD BE THERE AND THE ONES INSTALLED TO YOUR PSP WILL ALWAYS BE THERE.
Video Game Consoles & Games Logo
I need to know if the power source could be the problem. I already replaced the battery and it worked fine for a week, and then died. I already took it apart once and fixed the dpad, so that's not a p
This could be due to a faulty charging cable, a burnt-out battery or the interference of software you have downloaded. Solve these problems by testing your PSP to locate the charging problem and proceed to implement the correct solution.
Instructions
Revert to Factory Settings
1 Switch the WLAN button on your PSP so that it is in the "Off" position. Remove any memory stick or UMD that is in the system and put them aside.
2 Choose "Settings " from the left side of the cross media bar. Scroll to "Restore Default Settings." Press "X" to enter this menu. Press "X" to accept the restoration. The PSP will then revert back to its original settings.
3 Power off the PSP and plug it into an outlet with the AC adapter to charge for three hours. Power on the system to see if if the charging issue has been resolved.
USB Charging
4 Power on your PSP and scroll to the far left of the cross media bar. Choose "System Settings" and press "X." Scroll down the System Settings menu until you reach the option for "USB Charge." Press "X" and switch the setting to "On."
5 Return to the "System Settings" menu and choose "USB Auto Connect." Make sure the Auto Connect setting has been turned on. This allows your PSP to enter USB mode and begin charging whenever it is connected to another device.
6 Connect the PSP to a powered on PS3 or PC using the USB connector cable. The small end fits into the top of your PSP while the large end is inserted into a USB slot in your chosen system. The PSP will automatically enter USB mode as soon as it is connected.
7 Leave the PSP attached to the system for 30 minutes to an hour. When you detach your PSP, check your battery power. If it has gone up, then the charging problem is with your AC adapter. You can replace it or continue to use the USB charge function.
Battery
8 Plug your PSP into an outlet using the AC adapter cable and power on the system.
9 Enter the "System Settings Menu." Scroll down until you reach "Battery Information." Press "X" to open the menu.
10 Check the last option on the page which is labeled "Battery Status." If the status does not say "Charging," then the battery is not receiving a charge from the cable. While your PSP is getting power from the cable, you will need to purchase a new battery.
Oct 04, 2012 | Video Game Consoles & Games
what i need to do to connect my psp for internet
You will need a wireless router in order to connect the PSP to the internet
  • With your Psp turned on go to the "Settings" in the menu (scroll to the left)
  • Scroll all the way down until you have reached "Network Settings" and click the "X" button to enter
  • Select "Infrastructure Mode" and hit "X"
  • Select "New Connection" and hit the X button again
  • Now you will have a number of options for connecting to a wireless connection. Choose "Scan" and press the control pad to the left, the PSP will now scan for wifi signals around your area
  • When the PSP finishes scanning you will probably have a few different wifi connections. SSID is the name of the connection, the Security column tells you whether or not the connection is password protected, and the last one is the signal strength the higher the better
  • If you want to borrow your neighbors unprotected wifi select a connection with "None" in the security column and a strong signal. If you want to use a secure wifi than you will need to know the password. Select one and press the X button
  • Now the Psp will confirm your settings proceed by pressing left on the d-pad and save your settings
  • Now test your connection if you are able to connect, awesome. If you were not able to connect try doing the settings again
  • With the connection settings in place we can now connect the PSP to the internet. In the home menu scroll all the to the left until you have reached "Network" and go down to "Internet Browser" and hit "X"
  • Your browser will appear, select the little square box to enter the web address, play around with the different options. Have fun with your PSP online
Dec 16, 2010 | Sony PlayStation Portable (PSP) Console
i can't connect with my computer
Hello, I will guide you through the process to connect to your computer. Turn your PSP off, then connect the PSP to the computer. Then turn your PSP on again, using the psp press the home button located on the bottom left off your PSP and scroll left to the settings coloum. Scroll down to USB connection, then press X and the memory stick inside of your PSP will mount on your computer, inside my computer. Any further questions please feel free to ask.
Dec 08, 2010 | Sony PSP (Piano Black)
my psp files gone
I assume you have a PSP with customize firmware.
1. Turn on your PSP and press the "SELECT" button and the VSH Menu will appear.
2. Scroll down to USB Device and change the setting into "Memory Stick".
(Use the up & down directional button to scroll and use the left & right directional button to change the setting.)
3. Scroll down to UMD ISO MODE and change the setting to "SONY NP9660".
4. After you change the setting EXIT to the main console and restart your PSP.
If this solution did not work come back and we will try other solutions.
Jan 21, 2010 | Sony PlayStation Portable (PSP) Console
dont no how to connect the internet to a psp go
  • With your Psp turned on go to the “Settings” in the menu (scroll to the left)
  • Scroll all the way down until you have reached “Network Settings” and click the “X” button to enter
  • Select “Infrastructure Mode” and hit “X”
  • Select “New Connection” and hit the X button again
  • Now you will have a number of options for connecting to a wireless connection. Choose “Scan” and press the control pad to the left, the PSP will now scan for wifi signals around your area
  • If you want to borrow your neighbors unprotected wifi select a connection with “None” in the Security column and a strong signal. If you want to use a secure wifi than you will need to know the password. Select one and press the X button
  • With the connection settings in place we can now connect the PSP to the internet. In the home menu scroll all the to the left until you have reached “Network” and go down to “Internet Browser” and hit “X”
Oct 22, 2009 | Sony PlayStation Portable (PSP) Slim...
145 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
