Tip & How-To about Computers & Internet
How exactly to clean your laptop
Cleaning laptop case Cleaning the exterior portion of the laptop case can help keep the laptop looking new. The exterior case of a laptop can be cleaned by using a damp cotton cloth that has been dampened with water. It is not recommended that the exterior case of the laptop be cleaned with household cleaning solutions. However, if there is a substance on the laptop that cannot be cleaned with water, we suggest using rubbing alcohol.
Cleaning case openings
If dust, dirt, hair, or other substances are in the case openings, it can prevent air from getting into or out of the laptop. This can cause the overall heat of the laptop to increase, and in some cases may also cause such issues as random reboots.
Look for laptop openings where the laptop draws in cool air from outside or blows out any hot air from the inside of the laptop. These openings are usually on one of the sides, the back, or the bottom of the laptop. Dust, dirt, hair, or other substances can almost always be removed easily using a cotton swab and/or compressed air.
Warning: If you're using compressed air to clean the openings that have fans within them, it's possible that the amount of air blown on the fans can cause them to over spin, damaging or destroying the fan. To help prevent this issue, place something in-between the fan blades, such as a toothpick.
Cleaning laptop keyboard
Like almost everything else on a laptop, a keyboard is also different from the standard computer keyboard. With many laptop keyboards the keys cannot be completely removed. Therefore, we suggest cleaning the keyboard by using the same damp cloth you used to clean the exterior case of the laptop. In addition, compressed air can be used to spray any dust, dirt, or hair from in-between the keys.
If you've spilt something onto the laptop keyboard (like a soda) that's causing the keys to stick and cleaning it does not help we suggest that you have the laptop repaired since the keyboard cannot be replaced.
Cleaning laptop mouse (touchpad)
Cleaning the laptop touchpad can help improve the look of the laptop and also many times will help improve the responsiveness of the touchpad. To clean the touchpad surface, use the same damp cloth used to clean the exterior of the laptop.
Cleaning LCD display
Additional information about cleaning LCD and flat panel displays can be found on our main cleaning page.
Cleaning internal laptop components
Cleaning the inside of a laptop computer can be a difficult task. However, in some situations, it may be necessary because of excessive dust and/or dirt buildup within the computer, such as on the processor's heatsink.
Unfortunately, however, because of the complexity often involved in disassembling the laptop to reach many of these areas, Computer Hope cannot provide this information online for every laptop ever made. If you believe after cleaning your computer that it is still overheating because of dust and/or dirt buildup, we suggest taking the laptop to an authorized repair center.
Other cleaning information and help
Additional information and help with cleaning other portions of computers as well as discs and other computer related peripherals can be found on our main cleaning page.
Computers & Internet Logo
Looking for fuel gauge in tank portion
Hi, Johnheilman I would love to help you but I need the year, make, and model of your motorcycle please ask your question again and provide this information in the details box or comment section or edit your original question. Good luck and have a nice day.
May 02, 2016 | Tank Motorcycles
my HP CP1700 prints out gray tones in pink.
Your head / nozzles must be dirty , perform a nozzlecheck /head clean from printer software maintainance utility,
regards
Mar 28, 2008 | HP cp1700 Color Inkjet Printer
I see two small black spots on the viewer and then on the image when I upload to computer. Not on the exterior surface of the lens as I tried cleaning with damp q tip with no results. Any suggestions?
It sounds like you have some foreign objects on the inside portion of the lens or the actual mirror...since you have already tried cleaning the exterior of the lens, I suggest taking it to a qualified camera repair shop....or, if it is still under warranty, take to the store where it was purchased...
Oct 31, 2009 | Samsung S860 Digital Camera
laptop shut down on its own
Classic case of overheating.
Turn over notebook and remove bottom covers. clean out heatsinks near the fan.
The fan usually looks very clean, but look inside the fan housing and you'll probably find a blanket of lint/dust completely blocking the air passageways (even if they look clean from the outside).
If you remove the heatsink off the chips make sure you put on new thermal paste.
Some models it is very easy to get to the fans, others you have to fully disassemble the notebook
You could also try cleaning it out from the outside with an aircompressor, just leave it off for a day in case the is any moisture in the aircompressor lines. This may fix it but if its really clogged, you will need to open the unit and manually clean it.
HTH
JoshAU
Jun 02, 2009 | Computers & Internet
Remote needs to be too close to TV
Your remote is defective in that it does not send a strong enough signal to the tv. It is possible that the receiving portion of the tv could be defective but I have not run into that case on tvs that are so new. Since it is so relatively new I would ask for a new one and try it in the store. In either case you need to do this before the warranty is out on your new purchase.
Jan 21, 2009 | Televison & Video
287 people viewed this tip
David Payne
David Payne
