Tip & How-To about Computers & Internet
Cleaning your Motherboard effectively
Motherboard cleaningWhy? Dust and especially particles of cigarette smoke can build up and corrode circuitry causing various problems such as computer lockups
Note: When inside the computer take the necessary ESD precautions and try to avoid unplugging any cables or other connections.
Procedure: Our recommendation when cleaning the motherboard from dust, dirt, or hair is to use compressed air. When using compressed air, hold it in the up-right position; otherwise, it is possible chemicals may come out of the container that could damage or corrode the Motherboard or other component within the computer. Also, ensure when using compressed air that you always blow the dust or dirt away from the motherboard, or out of the case.
Another good alternative to compressed air is to use a portable battery powered vacuum that can effectively remove the dust, dirt, and hair from the motherboard completely and prevent it from getting trapped within the case. However, do not use a standard electricity powered vacuum as it can cause a lot of static electricity that can damage the computer. When using the vacuum it is vital that you stay a couple inches away from the motherboard and all other components to help prevent contact as well as to help prevent anything from being sucked into the vacuum. Ensure that you do not remove any small components with the vacuum such as jumpers.
Tip: When cleaning the inside of the case also look at any fans and/or heat sinks. Dust, dirt, and hair collects around these components the most.
Computers & Internet Logo
What is the tar in cigarettes?
Cigarette tar is a product of the burned resin of the tobacco leaves. What we call tar is actually a collection of tiny particles. Smoking a cigarette causes tar to be deposited on the respiratory tract.
Feb 06, 2013 | Cooking
PC cleaning Tips
Before you clean a computer or any component, be sure to turn the power off and unplug it from the outlet. Use caution when cleaning inside the computers case not to disturb any plugs or jumpers. If you do, this will make for difficult troubleshooting when you turn the computer back on.| Avoid spraying any type of liquid directly on to a computer component. Spray the liquid on to a cloth, then apply it to the computer component. Never use a house vacuum cleaner to clean the dust out of your computer case. House vacuums generate a lot of static electricity that can damage your systems components. There are portable battery operated vacuums available that are designed for use in a computer environment. It is fine to use your house vacuum to **** up the dirt and dust around your computer or even to **** the dust out of your keyboard. Make sure that you never get any component inside your computer wet. It is not advisable to use any cleaning liquid inside the case. You can use some canned compressed air to remove any dust from the case and case fans. Be sure to take your computer to a different location when blowing the dust out. Be sure to visit your computer manufactures web site to find out what cleaning solvents are recommended for cleaning your computer. I recommend just using warm water for almost any computer cleaning task. But if you need a stronger cleaning solution, be sure that it is highly diluted.
Mar 13, 2010 | Computers & Internet
I HAVE A PASSPORT 95OOi AND I AM HAVING A PROBLEM WITH THE LASER ALERT IT GOES OFF CONTINUALLY IN VARIOUS PLACES AS I DRIVE, BUT ESPECIALLY ON THE EXPRESSWAY I DON'T THINK IT'S WORKING PROPERLY WHAT COULD BE WRONG?
This is most likely caused by either a somewhat flaky power connection inside or on the back side of your car's cigarette lighter socket, assuming that you are using your 9500i's standard coiled Smartcord, or it is caused by excessive alternator ripple (electrical noise). Usually installing the optional direct wire power cable resolves this issue. Also Escort can reprogram your 9500i to desensitize its laser circuitry, but it would be better to try the direct wire power solution first. The direct wire solution usually resolves this problem, especially if you tap power in your fuse box from one of the higher amperage fuse terminals such as 15A. Why? Because the higher amperage fuses have heavier cable leading directly back to your car's battery and tend to be more free of electrical noise.
Jul 28, 2009 | Passport 9500i Radar/Laser Detector
it appears to have been on fire,surronding walls & unit covered i
hmmmm... maybe it was on fire... Barring that,
One thing to be aware of is how these things work: they don't actually filter the air. Rather, they electrically charge dust/dirt/etc. particles in the air as they pass through. This new charge makes them attracted to walls, floors, objects, etc. So rather than straining or filtering dust from the air (like a more traditional air filter), they make dust more likely to stick to walls, surfaces, etc. so that you can then wipe them up.
If there is something in the room that is manufacturing air pollutants, it could cause the problem you're having. The most likely culprit is anything that makes smoke. For example: smoking (duh), or burning CANDLES (especially scented candles) or INCENSE.
Jun 22, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
blades
Does anyone in your house smoke? Could be from cigarettes. I was told by the Ionic Pro Company to clean the blades with rubbing alcohol.
Mar 29, 2008 | Ionic Pro TURBO Air Purifier
172 people viewed this tip
David Payne
David Payne
