Tip & How-To about Cell Phones
Samsung GT-5603 add applications
Resources Required :
1. JAD Creator: Download Here ..
..(in case you have only JAR file)
2. TK File Explorer : Download Here
3. Samsung PC Studio : You must have got it with your brand new Samsung star 3G
Steps to Unlock Star 3G: Step 1. Connect Your Star 3G handset in PC Studio Mode
Step 2. Open Samsung PC Studio & Disconnect your Phone from software by right clicking the icon of phone. (Not from your USB)
Above step is must don’t open TK file explorer before that.
Step 3. Open TK File explorer
Go To >> Settings
Select COM Port whatever available as shown in figure & Keep rest things as it is. Click OK.
Step 4. Go To FILE >>Connect
Then the bottom dialogue box will open.
Go To> EXE > Java > Games
Step 5 : Create new folder in Games of the name of your Java Game or App. E.g, Opera
Then Open it (It must be blank) >> Then copy paste your JAR & JAD file there. (You can also navigate from upside dialog box & then download it. Its complicated, so better Copy & Paste)
And that’s it repeat same steps if you want to add more. Then GO to File >> Disconnect
Now you can remove Your Samsung star 3G from USB
Step 6 :
On your keypad type code : *#6984125*#
Then from the list Select > Internals
Then Enter following password or unlock code there *#9072641*# touch Confirm.
Then Select > Storage Mode
Now first click Update Java DB
Then scroll down & click Update Apps Database
Guess What You are done ….
Go back to your phone & application >> Games & More & you ll see your new apps or game appearing & working cool with your star 3G Device.
Cell Phones Logo
Jar files and few messages show 'unsupported file' while opening.
Jar file be easily open in a computer, but if you trying to open a .jar file in your Samsung phone, then you cannot open it directly. A jad creator is needed which you can download in the internet. It also required tk file explorer. You have to download this two from internet. After downloading you'll require a pc suite software of your mobile phone. Install a pc suite software of your mobile in your computer. after installation you have to connect your mobile phone to pc via data cable wire which came with your mobile phone. After connecting it open the TK file explorer which you have downloaded from the internet and follow the instruction for installation.
Mar 26, 2011 | Samsung Star GT-S5233 Cell Phone
opera mini5 beta2 not installing in samsung GT S3310
that model only supported to java s/w .........
Feb 14, 2010 | Samsung SGH-L700 Cell Phone
How can i install jar/jad files in my samsung S3310?
move to this link...
to install games...(.jar and .jad) http://3310metro.blogspot.com/
to download games:
http://3310goodies.blogspot.com/
to install themes..
http://samsung3310.tk/
Sep 16, 2009 | Samsung SGH-L700 Cell Phone
how i can install java games in samsung sgh e250 via card reader problem:
I got a beautiful answr on d net surfn 4 yr questn ...
You will need a *.jad and a *.jar file for your game. 1) Download Softick PPP and Samsung Java Uploader.exe . Also JADmaker if required. 2) Install SoftickPPP according to this Polish website. I don't understand Polish, but the pictures tell enough of the story. Set up your bluetooth COM ports in the SoftickPPP bluetooth/serial settings. My Bluetooth COM ports are either 24, 25 or 26. I leave them all ticked. 3) Enter *#52828378# on the phone to access the Java Test Menu. Choose OTA type setting, choose Serial bearer OTA. Click select. (This seems to need to be changed back to GPRS bearer OTA for Samsung PC Studio to connect) 4) Start SoftickPPP. Click on cancel for the missing USBPort.dll error message. Accept bluetooth connections for DUN and Serial connections on the phone. 5) Choose 'Activate PPP' by right clicking on the icon in the taskbar. Accept connections on phone again. 6) Start 'Uploader.exe' and then add the required jad file. Leave the program open. 7) If you are not still in the Java Test Menu then enter *#52828378# on the phone again. Select 'Serial test', 'PPP Up', 'Bluetooth' on phone, 'Serial download'. My phone sometimes restarts at this point in which case I have to choose 'Shutdown PPP" in the taskbar icon and then re-activating it once the phone has restarted and then re-do step 7 after entering the Java Test Menu again. A Java splash screen should appear with a progress bar showing the upload of the file. The game then starts automatically
.Quote:
1) Type in the code *#9998*52824678255# (which reads *#9998*JAVAINSTALL# )
2) Your phone should return with 'Activated'
3) Now using Bluetooth or USB cable, connect to your phone (IR probably works too)
4) If you have a game as .jar, but don't have a .jad file, use JadMaker to create one (draw the .jar file to it and it will generate a .jad file for you).
5) Copy the .jar AND .jad file of the game into the map called "Other Documents" on your phone.
6) Now on your phone under 'My Files' browse to the 'Other Documents' map and doubleclick on the just copied .jad file.
7) The phone will ask you if you want to Install the game.
8) After Install you will find the game under Games on your phone.
9) You can now remove the just copied .jar and .jad file again (they were only there to install the game onto your phone).
May 22, 2009 | O2 Samsung SGH-E250 Cellular Phone
438 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
