Tip & How-To about Cell Phones
How to remove those awful finger prints from a mobile`s LCD screen
it some times happens while repairing or doing something else to you rmobile that you get smudges and finger prints on the lcd which are very stubborn and using even a soft cloth can cause some scratches. so here is what you will do
use some standard strength scotch tape(The one which is not too sticky) and paste it on your lcd and then slowly rmeove it you will see that the smudges are gone...!!!. repeat this process until the LCD is crystal clear.
Hope this helps you guys.
Cell Phones Logo
smudge line on side of page
Smudges are most likely from the toner cartridge. If you can take your finger and run over the print and it smudges, then it is the fuser.
Aug 01, 2014 | Dell C1765nf Multifunction Color Laser...
I have a Canon Imagerunner 1023if and have black smudges along the left edge of paper, both copies and printed directly from computer.
this is possibly a problem in the fuseing part of your machine, where the paper heats up at the back, the fuser roller could be worn out. and your toner could be sticking to it.
Sep 05, 2012 | Canon imageRUNNER 1023iF Black and White...
the document printed from samsung scx 4200 printer has smudges and dots.
When you say smudges, can you wipe the toner from the page with your fingers; or is it just smearing when it prints; but, the toner is affixed to the paper?
1) If you can smear it with your fingers; replace the fuser. It's not heating the toner properly
2) If it is smearing, but sticking; replace the DRUM.
Nov 07, 2010 | Samsung SCX 4200 All-In-One Laser Printer
The printing on some letters smudges
Hello sir; Try to print out one page, use you finger to rease it ,is the image come off ? if answer yes, replace fusing unit.
Jan 08, 2009 | HP LaserJet 1020 Printer
Laser Printer
When the paper is fresh out of the printer, does the ink that looks okay smudge if you rub it with your finger? If so, it means the fuser is going bad. Otherwise, it's probably a bad toner cartridge that's leaking toner onto the paper.
Jun 12, 2006 | HP LaserJet 2100 Printer
129 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
