Tip & How-To about Computers & Internet
How to use multiple login on a single yahoo messanger
  1. Go to start > Run > Type regedit > Press Enter
  2. Click on the plus sign near the folder HKEY_CURRENT_USER
  3. Click on the plus sign near the folder Software
  4. Click on the plus sign near the folder Yahoo
  5. Click on the plus sign near the folder Pager
  6. Right Click on the folder name Test > New > DWORD Value
  7. Right side you will get a file named New Value #1
  8. Right Click on the file New Value #1 and Rename it as Plural and press enter
  9. Double Click on the file Plural
  10. You will get a windown named Edit DWORD Value
  11. Type 1 inside 'Select the Value data' and press enter
  12. Close the registery editor window
  13. Now you can launch multiple windows and use different ID's.
Computers & Internet Logo
Startup fails to complete properly
When on the screen, and you have no icons hold control(ctrl) down and shift key and press escape(esc) your windows task manager should appear, goto the applications tab, at the bottom goto the tab New Task and left click, another window should appear with a text bar, type in the text bar explorer.exe and click ok, all the icons and your normal screen should reapear.
If your screen goes back to normal goto the start bar and goto run or search and type "regedit".
When the regedit window appears left click the " + " sign next to Hkey_local_mechine the the plus sign on software, scroll down to Microsoft folder and click the plus sign, scroll down to Windows nt folder and click the plus sign, the plus sign on Current version folder, then scroll down to winlogon folder and left click on the folder icon, on the right hand side of the screen look for "shell" double click on the icon and delete everything in the text bar and type explorer.exe and click ok and exit out of the window, restart the pc and everything should be back to normal.
pls post back and tell me what happens.cheers.
Jan 30, 2010 | Computers & Internet
cd drive not detected
Lets do this.
1. Close all programs
2.Click on Start, Run, and type REGEDIT and press Enter.
3.click HKEY LOCAL MACHINE - SYSTEM - Current control set - control - class - select {4D36E965-E325-11CE-BFC1-08002BE10318} - on the right hand side you'll find upper filters and lower filters entries - right click and delete both(Upper and lower filters) - restart your computer and hope this works for you,
Awaiting response.
Thanks..
Sep 08, 2009 | Acer Aspireā„¢ T180 PC Desktop
supervisory password
1) Clikc Start, RUN
2) Type in RegEdit and select OK.
3) Now click on the little plus sign to the left of HKEY_LOCAL_MACHINE.
4) Continue to expand down, always clicking on the plus sign at the left of
the named key, through Software, Microsoft, Windows, Current Version and
Policies.
5) Now click on the Ratings folder.
6) In the right pane of the RegEdit window, you'll see an icon called Key.
Click on it and press Delete.
7) Next, choose Registry and then Exit to exit RegEdit. You've just deleted
your original Content Advisor password.
8) Restart the computer and run Internet Explorer again.
9) Choose View and then Internet Options (or Options for version 3.x)
10) Click on the Content tab and click on Disable. When asked for a
password, don't enter anything; just click on OK. This will disable Content
Advisor because there's no longer a password.
Mar 29, 2009 | Dell Inspiron 6400 Notebook
How Can I remove Windows Media Player from my computer.. the day i reinstalled my win xp sp2 it is not working it is also not allowing me to update it to windows media player 11.. i want to completely remove my media player or reinstall it.. how to do it ???
  • If is not located in the add/remove programs folder
  • Click the START button and select Run.
  • Type in: regedit in the command box.
  • When the regedit window appears, expand the HKEY LOCAL MACHINE by clicking on the plus sign to its right.
  • Now Click on the plus next to SOFTWARE, then MICROSOFT, then WINDOWS, then CURRENT VERSION and finally UNINSTALL
  • When you expand the Uninstall folder, you'll see all the programs currently installed, such as the uninstall Media Player 10 or Media Player, etc.
  • Click on the folder you want to uninstall, in the box on the right you will see two strings: DisplayName and UninstallString.
  • Double click UninstallString and a box will appear with the uninstall string highlighted.
  • Right click on the highlighted entry and select COPY.
  • Close the Regedit window.
  • Select the START button and click RUN.
  • Right click inside the command box and paste the uninstall string and click OK to uninstall Media Player
Jan 18, 2009 | Computers & Internet
my cd rom drive is not appearing on my computer i have an equium a210
follow these steps
Click start
Click run
type regedit
keep clicking the plus sign next to
Hkey local machine>>System>>Current ControlSet>>Control>>Class
Under class click on the first folder that starts fro 4D and it would be like 4D36E965
Now at the right hand side you will see options like upper filters and lower filters just right click and delte them
If you dont see both of them no worries delete the one that you see .After this restart your system.and check
May 25, 2008 | Toshiba Computers & Internet
104 people viewed this tip
David Payne
David Payne
