Tip & How-To about Computers & Internet
"Unable to find a free MBR slot in virtual partition.dll usually due to no free slots on disk"
Situation:
When attempting to run an operation in Ghost that requires a reboot into the virtual partition, you receive the error "Unable to find a free MBR slot in virtual partition.dll--usually due to no free slots on disk."
Solution:
This problem occurs when the client computer has used up all four primary partitions in the partition table of the boot drive. An Extended partition takes up one Primary Slot, so having three Primary partitions and one Extended partition would also cause this issue.
Computer architecture allows each hard drive to have no more than four primary partitions (the other partitions are extended partitions). Because the Ghost Virtual Partition is implemented as a primary partition, you see this message when the disk is using all four primary partitions and does not have an available slot for the virtual partition.
Use one of the following methods to resolve the problem
  • Start the computer from a Ghost bootable floppy disk rather than a Ghost Virtual Partition. You can use Ghost Boot Wizard to create a Ghost Standard Book Disk for this purpose.
  • Repartition the disk. If you repartition the disk, ensure that you create backups of your data before doing so.
Computers & Internet Logo
Unable to reinstall OS for Compaq Presario 5000.
Use ontrack disk manager
select advance installation
make partitions own do you want
after the completion process
take reboot
now install operating system that you like
even 98 or XP.
It will work 100% guaranteed.
Thank You
Aug 09, 2009 | Compaq Presario 5000 PC Desktop
MBR Error
The only thing that can be done is to scan and search for partitions (i.e. perform virtual partition recovery), and in case if something is found - display them and give the user an opportunity to save important data to another location. Third party software, like Active@ UNERASER, will help you here.The only thing that can be done is to scan and search for partitions (i.e. perform virtual partition recovery), and in case if something is found - display them and give the user an opportunity to save important data to another location. Third party software, like Active@ UNERASER, will help you here. for more contact http://tinyurl.com/m7ghqz
Jun 18, 2009 | HP Compaq Presario V2000 Notebook
one key recovery is deleted
if you mean to restore the one key recovery
copy the one key recovery partition from other laptop with Hiren all in one Cd
http://www.hiren.info/pages/bootcd
inside the cd you can found norton ghost
run it
then choose the operation
choose partition
choose to image
save to any partition
then proceed the image creation
then copy the file *.gho
to your hard disk drive
then make a partition that at same size with the one click recovery partition
then run again norton ghost at hiren CD like before
choose partition
choose from image
designate where the .gho file is located
then follow the prompt
------done------
Jan 24, 2009 | Lenovo 3000 Y410 Laptop
trying to reinstall norton ghost v14
you need to remove Norton with Nortons own removal tools. Add/remove program not the same thing as it leaves stuff in the registry. Go to norton.com and get removal tool..Run it, then try the re-install.
Dec 27, 2008 | Symantec Norton Ghost 14.0: Windows
3,264 people viewed this tip
David Payne
David Payne
