Tip & How-To about Computers & Internet
Computer common problems easy fix.
The most common problem with computers is them freezing up.
When applications dont load or freeze up.
The easiest way to fix most problems is usually just the simple act of "rebooting" the computer.
Most of us already know that.
but just in case you dont heres how.
when the computer seems frozen and you seem to have waited longer for it to unfreeze than it takes for bread to toast.. you can try the following.
press and hold the crtl anf alt buttons and double tap the del button.
on older computers using windows 98- 2000 and millenium editions it will usually reboot the computer. also works with older versions.
with xp and vista you will usually fet a differernt screen that will allow you to choose various options.. choose restart.
another way is to click on the start button located on the bottom left of your screen and choose restart option. if the computer is so frozen that nothing works you can press and hold the power button unti lthe computer shuts down.. wait 30 seconds and turn the computer back on..if that doesnt work then you may have to turn of the power switch..but only if you have to..with laptops you will have to take out the battery. when the comp reboots the computer should be unfrozen..if not you will need more help ..just ask us..
Computers & Internet Logo
Ice maker not working well ice was almost transparent now freezer not freezing blower is blowing cold but not cold enough to freeze any ideas?
I don't know what type of refrigerator you have, but the most common and hopefully the easiest fix is to Remove the grate on the bottom of refrig see if there's dust and hair and vacuum it out as best you can that will eliminate one problem.
Apr 10, 2015 | Refrigerators
Freezes after few minutes
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reg in out
Sep 11, 2010 | IBM ThinkPad T40 2373 Notebook
Toshiba Laptop - Startup freeze 40% of the time.
its a common thing for a vista based system to freeze after some updates , and my good advice to you is you better dont place too many applications on the startup , and avoid unwanted updating , ie8 is one such thing . if u have an option better switch to windows 7 , its really fast on notebook computers . install only defender updates from windows.
Jul 04, 2010 | Toshiba Satellite Laptop with AMD Athlon...
icemaker freezes up
Good day,
Common problem on all refrigerators.
It is usually caused by a bad water valve located on the rear bottom of the machine.
What happens, is it fills the ice maker, and is supposed to shut off completely.
If it dribbles instead of shutting off completely the water will start to freeze in the tube, and eventually freeze the tube shut.
Dec 12, 2009 | Refrigerators
182 people viewed this tip
David Payne
David Payne
