Tip & How-To about Kodak Digital Science 2500D Path-Through Scanner
Kodak 2500 scanner tires
Several years ago, Kodak stuck it to the owners of Kodak scanners. A simple, inexpensive consumable, tires, were taken off the market as a cheap thing to buy and they made it part of a care kit which just sent the price sky high.
If you own a 2500 Kodak scanner you can replace the retard tires with #13 O rings. They can be purchased from any Home Deport, Lowes....You will need a total of 12 O rings and that will cost you less than a buck. They work!!! I have been using them without incident for 2 years.
Kodak Digital Science 2500D Path-Through Scanner Logo
what is the kodak supplies new web adress
Kodak may have several internet sites. First, the manufactures has websites about resource logistical purposes. Second, kodak supporst would have internet sites that makes available technical resultion features amongs several expert skills requestable. Third, kodak retail have internet sites as customer relations requeest resolutions. Fourth kodak affiliates provide internetworking with sites to achieve resourcefulness. Mentionable examples of sites that relate to kodak inlcudes marketing establishments, amonsg camera devices technicians and device owners fun sites. Refering to the kodak products user guide may provide the exact website associated with customers perchuses. Once on the internet, search for kodak as type scripts would produce several results from which found similar requests.
Feb 05, 2011 | Computers & Internet
It appears that pictures are being taken with the lens cap on - when that's not the case. In other words all camera indications are that the picture is "taken", but it is a black square. I'm thinking a mechanical problem with shutter? The camera seems to "think" it is taking a picture.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Jan 12, 2010 | Kodak EasyShare DX4530 Digital Camera
Road Noise
if your looking for a really good inexpensive tire that will last you a while i will suggest the Hankook tires. i have owned them in sizes running from 38 12.50 15 to 225/75r15 they are a great tire and virtually no road noise at all. and they are actually very good priced as far as inexpensive.
please rate me if you would
thank you
Aaron
May 22, 2009 | 2006 Ford Escape
Kodak i40 Scanner - paper jamming
First clean with a damp cloth, then try Isopropyl Alcohol. Dont use solvents. Check if papers are sticky. Stapled papers are 'sticky' even after removing staples. loosen them if required. Notmally rollers last 200,000 to 250,000 scans
S. Mohan, Chennai, India
Mar 17, 2009 | Kodak i40 Path-Through Scanner
Blue screen only now on all inputs....
Good Day,
nniemeryer;
NO not simple problem. This dlp has so many problems that you have not experienced yet but you will. To repair this concern will be into the same $7-800.00 range again.
Not much of a market to sell this but can try local service shops/ or internet type places.
But let's not get too much in front of ourselves. I would call the manufacture and complain and try to get them to repair unit, tell them (they know) you know that TV is having a lot of problems and service bulletins written on this model. Here's their info:
Consumer Relations
Consumer Issues
Phone 7:00AM - 5:00PM PST ......(800)332-2119
Dealer or Servicer Referral(24HRS)..(800)332-2119
FAX (24HRS).........................(949)465-6147
FAX Document Retrieval System(24HRS).(800)332-2119
I hope this has been helpful,
big IRISH.
Jun 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
1,407 people viewed this tip
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
