Tip & How-To about Office Equipment & Supplies
How to uninstall USB driver of a printer
1. Click start ->Run.
2. In the Run window, type "devmgmt.msc" (without quotes), click OK.
3. Device Manager Window will pop out, in this screen at the bottom you will see "Universal Serial Bus Controllers"
4. Click on the(+) sign next to "Universal Serial Bus Controllers" and look for "USB Composite Device".
5. Right click on "USB Composite Device" and select Uninstall.(Read Note)
6. After the the device is uninstalled, disconnect the USB cable from the back of the computer.
7. Restart the computer, after the system is booted plugin the USB cable.
8. You may need to wait for sometime for the device installation to get complete.
9 . Then try to print a word document.
Note: Before uninstalling the "USB Composite Device" right click on it and select properties to confirm whether that driver is for the printer.
Thanks & Regards,
Rizwan
why the windows7 cannot recognize the usb cable device of psvita
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
Oct 07, 2012 | Microsoft Windows 7 Home Premium 64BIT...
gateway 310 s won't recognize a cd
Method 1: Initiate recognition of the USB device by using Device Manager loadTOCNode(2, 'workaround'); To initiate recognition of the USB device by using Device Manager, follow these steps:
1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
2. Click to select your computer as the location for the scan.
3. On the Action menu, click Scan for hardware changes.
Windows XP recognizes the new device.
4. Close the Device Manager window.
If this method resolves the issue, you are finished.
If this method does not resolve the issue, go to method 2.
Method 2: Disable power management of the USB hub loadTOCNode(2, 'workaround'); Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps:
2. Expand Universal Serial Bus controllers.
3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
4. Click the Power Management tab.
5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
6. Repeat steps 3 through 6 for each USB Root Hub in the list.
7. On the Action menu, click Scan for hardware changes.
8. Close the Device Manager window.
If this method does not resolve the issue, go to method 3.
Uninstall all the usb controller from USB controller
and now restart the computer.
If this method does not resolve the issue, go to method 4 .
Method 3: Restart the computer loadTOCNode(2, 'workaround'); To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
Hope this helps.
Jan 14, 2011 | Gateway 310 S PC Desktop
MY COMPUTER DOES NOT RECOGNISE THE IPOD TOUCH AT ALL ALTHOUGH IT CAN CHARGE ITSELF
Solution 1 -
Solution 2 -
Feb 02, 2010 | Apple iPod touch
423 people viewed this tip
jasbo
jasbo
