By
HDTV GURU
Rank: Guru
Rating: 86%, 91 votes
posted on Feb 18, 2008
If your picture looks 3D then you most likely have a CONVERGENCE IC that is bad or a fuse that supplies 12vdc or 25vdc to that IC IS OPEN. Also keep in mind it could be a FRACTURED solder connections. The cost of the IC varies depending on which one it is.
Did you find this Tip Helpful?
Can you Help with these Projection Televisions problems?
Sony KP-46WT500 46 in. Rear Projection...
i turn on the tv it start binking however, tv does not...
Had dish network come out and hook everything up, and my...
Hey there, I have the same problem, were you eer able to...
i'm getting a red and green shadow on the picture. Also,...
one of the sides of the screen is not inside the...
Sponsored Links
