Tip & How-To about Microwave Ovens
Whirlpool single/double oven NO HEAT AFTER SELF CLEAN
Problem: you have just cleaned your oven
now the unit won't heat at all.
Solution: There is a thermal cutoff in the very back of the unit
YOU ARE GOING TO HAVE TO TURN THE POWER OFF
take the unit out of the hole
take the back panel off
you will find to the upper left the thermal cutoff
it's a round component with 2 wires going to it either 2 orange or 2 red wires
take it off if you have an ohm meter check continuity
if you have no continuity it is bad
Tip: Go to FRYs or maybe home depot
The stuff you need is called FREEZE IT
with gloves on or just stick the component on the ground upside down
spray the FREEZE IT to the back of the component till it turns white
get your screw driver and tap the back of it a couple of times
check for continuity if you have regained continuity
put it back on and put unit back together
You should be back in business
if you cannot find FREEZE it try sticking it in the freezer overnight
then tap on with screw driver/check continuity
if the continuity never comes back then you are going to have to replace that part.
But for the most part this usually works.
Microwave Ovens Logo
Not heating food up
please make this test and fix it. Use the multimeter.
Merry Christmas.
  1. Check the power diode This electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitor Responsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetron Responsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal Cutoffs Examine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Dec 16, 2013 | Daewoo Microwave Ovens
microwave does not heat
please follow this steps and fix it. God bless you
Dec 09, 2013 | Panasonic NN-S561 Microwave Oven
unit does not heat
follow this steps.and fix it. God bless you
Dec 09, 2013 | Microwave Ovens
microwave runs but doe not heat
follow this test and fix it. God bless you
Nov 26, 2013 | GE JVM1190 Microwave Oven
wolf convection microwave
see the next steps , use the VOM and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Jun 17, 2013 | Microwave Ovens
142 people viewed this tip
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
