Tip & How-To about Whirlpool Duet GHW9150P Front Load Washer
Replacing the Drain Pump on a Whirlpool Duet
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain and the drain pump does not run at all, here’s the information you need to replace the drain pump:
Symptom: PUMP IS NOT RUNNING, NOT DRAINING AT ALL.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. Sometimes objects get caught in the pump impeller and stop it from running. We’re going to assume that you have already done this and that the pump no longer runs. It is strongly recommended that you remove all residual water from the wash tub & drain line at this point or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. HINT: Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  7. Locate the electrical connection to the pump and disconnect.
  8. Now locate the two drain lines and remove them. The hose clamps can be released by squeezing with a pair of pliers. NOTE: I would not recommend removing the hose from the bottom of the wash tub unless you really have to. This one can be difficult at times to get back on.
  9. Remove the torx type screw at the front center of the pump and it should slide right out of the mounting grooves on the bottom of the washer case.
  10. Your new pump comes with several adapters to place on the feet of the pump in order for it to properly fit your washer. These are rubber bushings that help get rid of vibration and noise. If you become confused, there should be installation instructions that come with your new pump. You can also look at the pump you just removed to see how the bushings are mounted.
  11. Reinstall the drain lines to the pump. HINT: It is much easier to do this with the pump still OUT, rather than installing it. When you squeeze the clamps to open them up, make sure you slide the clamp completely over the hose AND the inlet/outlet tubes on the pump housing in order to get a good seal.
  12. Reinstall pump by sliding the feet of the pump into the mounting grooves on the bottom of the washer case. Tighten the center screw and reattach the electrical connection.
  13. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  14. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  15. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump is supposed to energize and begin to drain.
  16. If the pump works normal and there are no leaks detected, reinstall panel and tighten screws.
CAUTION: Use care when reaching inside the washer case not to damage the small wire harness that runs along the front of the machine.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Whirlpool Duet GHW9150P Front Load Washer Logo
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Drive Belt Installation on a Whirlpool Duet or Kenmore Elite Front Loader
    Thanks for this helpful information! I noticed that the drum pulley is very wobbly, yet the holding bolt is tight, is this normal? Should the pully be firm and not wobble or rotate?
    Sep 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore Elite & Whirlpool Duet Washer and Dryer Control Panel Locked
    this was helpful! took three screws out, loosened a flex clamp and blew through the tube to free the impeller. saved a service call!
    Jun 27, 2009 | Kenmore Elite 45986 Front Load Washer
    The machine is locked and can't open with clothes washed inside,. Add garment light is on and the time is flashing'
    Whirlpool-made Front Loading such as the Kenmore Elite washing machines use a door lock and switch assembly having a tab that can be pulled manually for emergency opening of the door. This tab can be accessed with the removal of the lower front access panel. Disconnect power to the washer and drain the water from the tub before accessing it. The link below contains the detailed instructions on manual unlocking of the door.
    Manual Unlocking of Whirlpool Duet and Kenmore Elite Front Load Washing Machines
    Aug 26, 2011 | Kenmore HE2 Plus Front Load Washer
    9,893 people viewed this tip
    Dan Webster
    Dan Webster
    Sal DeAngelo
