Tip & How-To about Washing Machines
How to fix your washer if it does not drain or spin
Kenmore whirlpool,roper,kitchenaid,estate,inglis washer if it will not drain or spin,it's a bad lid switch,remove the 2 head screws,flip the top up,pop the 2 spring clip,unplug the lid switch,pull the cabinet off,remove the 2 screws under the lid,replace switch,put everything back together and your done,most times the model number is under the washer lid-mike
Washing Machines Logo
washer fill with water model # LA4800XTW0 then just sits there no agiate no spin water will then drain once switch is manually advanced. Lid switch problem? OR direct motor coupler?
Hello, welcome to FixYa.
Based on your post, if you mean manually advancing the timer it will drain, it's a coupler. If you mean manually activating the lid switch, it is the lid switch or lid switch strike.
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...based on the model provided, it cover's yours)
Thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Aug 14, 2011 | Whirlpool Washing Machines
my kenmore 70 series washing machine does not drain and now will not spin.
bad lid switch,by pass it,remove the 2 plastic end caps on the head if it has them,there is a screw on each side,remove them,flip the head up,unplug the lid switch jack on the washer,,cut the 2 outside wires and wire nut them together,plug back in and your done,let me know how you make out-mike
May 07, 2009 | Kenmore Washing Machines
I just bought a used Kenmore 70 series washer, model #20712990. It will fill and agitate, but after that it seems to get stuck "soaking." I moved the timer forward to rinse, and it agitated again, but it never drained and re-filled. It isn't spinning, either, since it won't drain. HELP!
all that is wrong is the lid switch is bad,remove the 2 head screws one on each side,flip the head up,you will see the lid switch jack on the washer top,unplug it clip the two outside wires and wire them together(unplug the washer first before you start this)now plug the jack back in,you have now by passed the lid switch and your good to go,let me know how you do-mike
Mar 21, 2009 | Kenmore Washing Machines
Washer won't spin,rinse,or drain
BAD LID SWITCH,YOU CAN REPLACE IT OR BY PASS IT,REMOVE THE 2 CONSOLE HEAD SCREWS ONE ON EACH SIDE,FLIP THE TOP UP,YOU WILL SEE THE LID SWITCH JACK,YOU CAN CUT THE 2 OUTSIDE WIRES AND PUT THEM TOGETHER WITH A WIRE NUT AND PLUG BACK IN,YOU HAVE NOW BY PASSED THE LID SWITCH AND YOUR GOOD TO GO-MIKE
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
176 people viewed this tip
Top Washing Machines Experts
