Tip & How-To about Dishwashers
How to get help so you can fix you own appliance
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your model number is needed in order for someone to help with the diagnosis or your appliance. There are lots of different parts and each model is different. Post this number in the description of your problem and you'll be much more likely to receive the help you need .
It's usually stamped on a small tag in a visible location on your appliance.
On your refrigerator look
Behind the lower toe kick-plate, Behind the lower crisper drawer, On the face frame of the refrigerator body, Inside the refrigerator of freezer on the left or right side wall.
On your oven look Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} on the back side of the door at the bottom or edge. On the vent trim behind the center of the door.
Washer-Dryer
behind or on top of the control panel. Behind the door. On the lower front or side of the cabinet.
Dishwasher-
Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
Microwave-
on the face frame behind the door or on the back.
Dishwashers Logo
Older model Weedwacker Trimmer/Edger with flip switch on shaft that converts trimmer to edger. No serial/model number/manual. Need to order the metal guide (curved, v-shaped) that fit under shield. Help!
You will probably have to find someone who has the same model or a different model but has the part that looks the same and get there model numbers. You may just need to take a good look at yours and go to Sears to see if theirs are identical. Then get the model number information and order your parts. You can order by searching Craftsman parts and going to the Sears website and entering the model number and finding the part on the illustrated parts diagram and then look to the list at the right of the screen and find that number to get your part number to order. You will be able to order or if you look at the top of the page (i think) you can call order if you prefer.
Jul 07, 2011 | Craftsman 25cc Gas Line Trimmer
where is the water filter on a 1998 kenmore fridge
Here is where the confusion begins. When Kenmore says their model number, it is different than OEM numbers or original equipment manufacture's number's. Here is the deal with Sears when it comes to their model numbers. Sears buys all their products from someone else like Whirlpool, Maytag, GE and the list goes on and on. Then Sears calls their model number Kenmore Model Number=> Kenmore Model Number Locator's and the first three numbers are the models maker or who originally made the appliance Click Here for examples=> Kenmore Appliance Model Number Prefix's or Click=> Here once you have the correct Kenmore Model Number once you have that then you can find the parts for your dispenser. Your number will look like this for example only 363.235698 then go to Parts Direct or Repair Clinic and enter the correct Kenmore appliance model number and then search dispenser parts for that model numbers parts number. Hope I made this simple enough so if you need assistance I will be here to help you find that one small part you are searching for, Thanks, for understanding, Sea Breeze Once you find that 363.235698 example you will be well on your way!
May 05, 2011 | Kenmore 52642 / 52644 / 52649 Side by Side...
The ice dispenser when pressing it in with a glass does not work, it doesn't seem to push in far enough to activate the ice dispenser but I can reach in with my finger and pull on it and it then will activate, is there a part I need to replace in order for it to go farther inz/
Yes the number you are searching for is called an OEM number or original equipment manufacture's number. Here is the deal with Sears when it comes to their model numbers. Sears buys all their products from someone else like Whirlpool, Maytag, GE and the list goes on and on. Then Sears calls their model number Kenmore Model Number=> Kenmore Model Number Locator's and the first three numbers are the models maker or who originally made the appliance Click Here for examples=> Kenmore Appliance Model Number Prefix's or Click=> Here once you have the correct Kenmore Model Number once you have that then you can find the parts for your dispenser. Your number will look like this for example only 363.235698 then go to Parts Direct or Repair Clinic and enter the correct Kenmore appliance model number and then search dispenser parts for that model numbers parts number. Hope I made this simple enough so if you need assistance I will be here to help you find that one small part you are searching for, Thanks, for understanding, Sea Breeze
Apr 21, 2011 | Kenmore Side by Side Refrigerator
We have a kenmore elite king size capacity top load washer and the model no tag is missing. It's the type of washer where you have to slide a putty knife under the control panel to lift the panel as opposed to the control panel being secured by screws. The control panel is not secure since those springs that hold the control panel down are missing. Need to find part number for those missing springs or a model number for a compatible washer that uses those springs. thanks
Do a search for "appliance parts". When you do that you will have a large number of different websites come up from your search.
You will then need to have the model number of your appliance handy. The make will usually be identified by the model number so just the model is usually sufficient. Sometimes a model number will not work in one site, so try a different site.
When the parts page comes up you usually will have access to "exploded diagrams" which will help you to identify the part that you need. The pictures on some of the sites are better than others, so look around till you find what you need.
Once you know what you need, check out another site or two, or three. The price you get from one may be quite different from another. Also just because site A had the best price for one part, it may not have the best price for the next part you need. It seems that the different sites will use some parts to get you to buy and then soak you for another part.
Please check the bellow link to order the parts or contact customer care for guidance:-
http://www.repairclinic.com/Washer-Dryer-Combo-Parts
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Oct 06, 2010 | Washing Machines
160 people viewed this tip
Top Dishwashers Experts
