Tip & How-To about Cameras
"Memory card Error"
Remember Memory card are having a limit of lifetime deta loading limit. For example: 0000001 - 2000000kb/md etc. When you format dont thing that range are deleted. tahst counting continue.
So long tims single memory card/ flash drive uses dont shocked if its showing Error. Specially digital camera user. And also one more tips that when you face those problem 1st scan the memory card for finding or cleaning virus.
Cameras Logo
how to load pictures to the frame
place images etc in any of the following formats
Supporting formats: jpeg,exif, mov,avi,mpeg1,mpeg4.
on one of the following cards,
Supporting cards: SD,MMC, MS,xD, CF,MD.Remote control. USB, 128Mb integrated memory.
or via usb cable onto the intergrated memory
when connected to pc and switched on will show up like a new harddrive or stick.
move pictures to this drive and they will be on frame internal memory.
or move images etc to sd card or usb stick,
insert card or stick into relevent slot or port on frame and switch on
images should be able to be viewed.
I hope this was useful.
Jan 24, 2011 | Kodak EasyShare SV811 (8858946) Digital...
My computer or memory card wont allow me to load my pictures
Its a problem of your card. your memory card may infected by virus so scan the card by updated virusfree conputer. If there is nothing gonna find then remember one more thing that all memory card have a life time. If the card corss the limit of lifetime image capacity that time its happend like these way.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
i just put music on my card but i dont know how to load it onto my phone. can someone help?
First you need to make sure that the music files that you put on the card are compatible with your phone. You have to tell the phone where to look for the music files. Access the menu on your phone, and look for "memory." You have some limited memory on your phone itself, but you want to access the memory card. You can also set your phone to "save to" the memory card as well for videos, etc., this way you won't fill up your phones memory, and it is easy to transfer you files between your phone and other devices, computer, etc. My phone for example will play only the files on my phone by default, until I set it to play files from the memory card. You need to learn more about your particular phone, not so much the memory card itself. Please rate appropriately and leave a response. I hope this helps and good luck.
Oct 23, 2009 | PNY 2GB microSD Memory Card
I load regions to sd card and meridium platium does not recognize
You do not need to screw with an SD card, they are formated to take whatever data you send to them, but in your case check by reading the card to see what is on it BEFORE you put it in the GPS. It may have junk files on it, thus there is no room, unless of course you try to load to much data, THERE IS A LIMIT, suggest you read the GPS manual, and see what the limit of the size of the card is for that GPS, yes there is a limit!
Jan 13, 2009 | Magellan Meridian Platinum GPS Receiver
can only take about 5 photos at a time and then only after reformatting the memory card.  After about 5, I get one of two error messages "camera cannot display image" when I try to playback or "memory card error"
The card may be done. Thay have a limited lifetime, and if it was a cheap card in the first place.......
Reformatting does not fix this, the formatting software will scan for bad sections of the card and exclude them form the format.
It could be that there is a problem with formatting from the camera. But a card reader to fit to the PC and download the card formatting program from the official SD standards website. If your card can be properly formatted then this will do it.
Nov 29, 2008 | Pentax K20D Digital Camera
183 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
