Tip & How-To about Computers & Internet
Delete an undeletable File
Open a command Prompt window and leave it open.
close all open programs.
click Start, Run and enter TASKMGR. EXE
Go to the Processes tab and End Process on Explorer. exe.
Leave Task Manager open.
Go back to the command Prompt window and change to the
directory the AVI ( or other undeletable file) is located
in.
At the command prompt type DEL where
is the file you wish to delete
Go back to Task Manager. click File, New Task and enter
EXPLORER.EXE to restart the GUI shell.
close Task Manager.
or you can try this
Open NOtepad.exe
click File>Save as..>
locate the folder where ur undeletable file is
choose "All files" from the file type box
click once on the file u wanna delete so its name appears
in the "filename" box
pur a " at the start and end of the filename
(the filename should have the extension of the undeletable
file so it will overwrite it)
click save,
It should ask u to overwrite the existing file, choose yes and u can delete it as normal
Here's a manual way of doing it. I'll take this off once you put into your first post zain.
1. Start
2. Run
3. Type: command
4. To move into a directory type: cd c:\*** (The stars stand for your folder)
5. If you cannot access the folder because it has to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces.
Example: cd c:\progra~1\kazaal~1
6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.
7. Now to delete the file type in del ***.bmp, txt,jpg,avi,etc... And if the file name has spaces ypu would use the specific folder throgh command, del badfil~1.bmp and your file should be gone. Make sure the type in the correct extension.
Computers & Internet Logo
spysweeper program damaged after a.exe download
isass.exe is registered as the Optix.Pro virus which carries in it's payload, the ability to disable firewalls and local security protections, and a backdoor capability
How Do You Remove Isass.exe Files in Windows XP and Vista:
  1. Click your Windows Start menu, and from “Search,” click “For Files and Folders….”
  2. A speech bubble will pop up asking you, “What do you want to search for?” Click “All files and folders.”
  3. Type a Isass.exe file in the search box, and select “Local Hard Drives.”
  4. Click “Search.” Once the file is found, delete it.
How to stop Isass.exe processes:
  1. Click the Start menu, select Run.
  2. Type taskmgr.exe into the the Run command box, and click “OK.” You can also launch the Task Manager by pressing keys ALT + CTRL + DELETE or CTRL + Shift + ESC.
  3. Click Processes tab, and find Isass.exe processes.
  4. Once you’ve found the Isass.exe processes, right-click them and select “End Process” to kill Isass.exe.
How to remove Isass.exe registry keys: (Do not delete anything other than what is listed below.)
  1. Select your Windows menu “Start,” and click “Run.” An “Open” field will appear. Type “regedit” and click “OK” to open up your Registry Editor.
  2. Registry Editor will open as a window with two panes. The left side Registry Editor’s window lets you select various registry keys, and the right side displays the registry values of the registry key you select.
  3. To find a registry key, such as any Isass.exe registry keys, select “Edit,” then select “Find,” and in the search bar type any of Isass.exe’s registry keys.
  4. As soon as Isass.exe registry key appears, you can delete the Isass.exe registry key by right-clicking it and selecting “Modify,” then clicking “Delete.”
How to delete Isass.exe DLL files:
  1. First locate Isass.exe DLL files you want to delete. Open your Windows Start menu, then click “Run.” Type “cmd” in Run, and click “OK.”
  2. To change your current directory, type “cd” in the command box, press your “Space” key, and enter the full directory where the Isass.exe DLL file is located. If you’re not sure if the Isass.exe DLL file is located in a particular directory, enter “dir” in the command box to display a directory’s contents. To go one directory back, enter “cd ..” in the command box and press “Enter.”
  3. When you’ve located the Isass.exe DLL file you want to remove, type “regsvr32 /u SampleDLLName.dll” (e.g., “regsvr32 /u jl27script.dll”) and press your “Enter” key.
That’s it. If you want to restore any Isass.exe DLL file you removed, type “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32 jl27script.dll”) into your command box, and press your “Enter” key.
Did Isass.exe change your homepage?
  1. Click Windows Start menu > Control Panel > Internet Options.
  2. Under Home Page, select the General > Use Default.
  3. Type in the URL you want as your home page (e.g., “http://www.homepage.com”).
  4. Select Apply > OK.
  5. You’ll want to open a fresh web page and make sure that your new default home page pops up.
Block Isass.exe sites: www.eKerberos.com
Stop Isass.exe processes:
Get rid of Isass.exe DLLs: %PROGRAM_FILES%\ eKerberos\ Hook.dll
Delete Isass.exe folders: %PROGRAM_FILES%\ eKerberos\
Please rate this a fixya
Feb 08, 2009 | Webroot Spy Sweeper (spysweeper) for PC
Delete An "undeletable" File!
All Problems have ONE solution and that is: www.longPathTool.com Path too long. Error cannot delete file: cannot read from source file or disk Cannot delete file: Access is denied There has been a sharing violation. Cannot delete file or folder The file name you specified is not valid or too long. Specify a different file name. The source or destination file may be in use. The file is in use by another program or user. Error Deleting File or Folder Make sure the disk is not full or write-protected and that the file is not currently in use. Path too deep.
Dec 10, 2010 | Computers & Internet
163 people viewed this tip
David Payne
David Payne
