Tip & How-To about Yamaha Full-Size Keyboard
How To Take A Picture Of Screen (W/O A Camera)
On Your Keyboard, Push The Print Screen Button (May Say "PRT SCR"), Nothing Will Happen. Open Paint, Or Some Photo Editing Program - I Recommend Paint - And Go To Edit>Paste. It Should Paste A Picture Of Your Screen. Ready To Be Saved From Paint To Your Computer. Another Trick, If You Hold Alt While You Push The Print Screen Button, It Will Take A Picture Of Just The Active Window You Are On.
Yamaha Full-Size Keyboard Logo
Is there a way to program the whole keyboard to play 1 octave lower?
You can use TRANSPOSE/SETTING button.
Each press the TRANSPOSE/SETTING button cycles through the setting screens. If you accidentally pass the screen you want to use,keep pressing the TRANSPOSE/SETTING button untill the screen appears again.
To lower by one octave,set the value to -12
You also can use PIANO SETTING button.
Find the setting in page 07 of PIANO SETTING.
Sep 03, 2015 | Casio CTK810 61 Key Keyboard
I have a Yamaha PSR 2000 keyboard. You can not see the keyboard. It lights up but you can not read anyting on it. It is blank. Can it be replaced what part would one need to fix the problem? I had scr
If you have a light behind the screen then the backlight is working. It could be a connection from the board to screen but this is very unusual.
These screens have been know to fail and will need replacing.
HOWEVER
The screen is not a simple and requires an extra driver board and various components to be replaced/changed. You will need soldering equipment for surface mounted resistors etc if wish to undertake this.
The replacement kits including the screen cost around £ 400.00
Have you tried a factory reset?
Hold down top / highest white key whilst turning the keyboard on.
Good luck
Jan 05, 2015 | Yamaha Music
how do i edit and store midi files on my tyros keyboard.
Storing is easy... editing is NOT so easy and is better done using a PC with an editing program.
Not knowing which model Tyros you have, either bring the MIDI files on floppy disk or USB stick.
Select the floppy or the USB source on the Tyros while in the song mode. Find and COPY a file or files, then move back to the place you want to store them like hardrive or user space and PASTE. You can create folders before each to keep the things seperate.
Oct 28, 2009 | Yamaha Full-Size Keyboard
Casio PX-320 Keyboard has no MIDI driver for MacOS
It would not be a "driver"... if anything you would need a music editing program. Some examples are like "Cakewalk", "Sonar" etc. This assumes you have a MIDI port on your PC. If not, a driver will come with the MIDI interface you need and buy.
Sep 02, 2009 | Casio Privia Keyboard Case
Casio Privia keyboard PX-100
There are a number of issues that could cause this, the most likely culprit is the power supply, when I say power supply I mean the internal power supply,
This means that you have already obtained a good "known to work" AC to DC power supply, and tested it on your keyboard to see if that is the problem.
If you have completed this step, then your next step is to test your unit with batteries only, if the keyboard works, then you know your problem, is internal to the keyboard.
There are two issues to check, before proceeding please read the following note.
 (a note here for those who have no experience working with internal electronics)
If you have no experience working with internal electronics I would not recommend, opening your keyboard.
Two reasons, one, will void warranty if it still is under warranty.
secondly, you could accidently cause more damage to the unit.
Now if you are still reading, and feeling confident, you know that as a child you have dissembled many many electronic devices, just to see how they work.
If you do decide to open the box, disconnect the power supply to the unit including any batteries.
open the box and locate the power on button, clean using a Dielectric cleaning agent, can be obtained at most electronic specialty stores.
clean the power button, may work but doubtful, usually the switch itself is usually bad, there is a way to test the switch, however, that is beyond the scope of this answer, if you are following this you will most likely have the knowledge to do this.
The second and more challenging issue will be the internal power supply to the keyboard, or the interface that connects to your ac to dc converter.
This can be much more trickier, and I wont go into it here.
If you test your power switch determine that it is good then you should consider getting the unit serviced by a technician.
If you examine the boards, (electronic circuit boards,) and notice burned, connections, (darker than other circuits) then most likely it will not be worth trying to fix.
Hope this helps somewhat, if nothing else, take this print out to your local service dealer, and that will help in getting your keyboard repaired,
Delete this part, before taking this to your dealer,
Most electronic products can be easily fixed with a power switch, or power supply, however, many dealers will not tell you this and give you an estimate of fixing the unit that far exceeds the actual cost of repair,
an example, in a local TV repair shop, a friend brought in a wide screen Plasma HD TV, quoted repair, $654.00  problem,
power supply, actual cost, $75.00 my friend ordered the part online and with the help of a friend installed the new power supply returning his unit to full functionality.
So beware,
Jan 15, 2008 | Casio LK30 Note Lighted Keyboard
1,417 people viewed this tip
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
