Tip & How-To about Cuisinart DCC-1200 Coffee Maker
How to clean the inside of your coffeemaker
When coffeemakers make only a few cups of coffee instead of the whole pot, it's usually because the heating element is covered with hard water deposits. To fix it, you just need to run white vinegar through it. Put white vinegar in the same way you do water (but don't put any coffee grounds in the basket). Run it as many times as it takes to get all the vinegar out, and then run it again three or four times the same way. After it runs normally, run water through it until the vinegar smell is gone.
The cause of the slow brewing is that the water you normally use has some amount of hardness to it, and over time the hard water minerals build up on the heating element inside the machine. The buildup prevents the heating element from heating the water as fast as designed. The vinegar will dissolve the minerals and let the heater work at full capacity again.
If you want to avoid this in the future, just run the white vinegar through it once a month or so even if it's not running slow.
Cuisinart DCC-1200 Coffee Maker Logo
Vinegar solution cleans mr coffee modelJWX23 but can it be taken apart to clean it better the coffee doesn't come out real fast for long
No. This coffeemaker is not built to be serviceable in that regard.
You can wipe down the inner-sides of the reservoir for a slightly better maintenance cleaning. But, 4 cups of pure white vinegar (no water added) in the hour-long cleaning cycle followed by two pots of fresh water in the brewing cycle is really the best way to clean the rest of the inner-parts which contact the liquids.
If your real purpose for your question is how to resolve the elongated brewing times, I'm afraid that is a symptom of damage to the heating element. This too is not serviceable.
The heating element will naturally degrade over time. But, it can incur sudden damage when the reservoir is refilled with water too soon - while the element is still hot. Because of the simple design, if the coffeemaker is one, then both the warming plate's heating element and the reservoir's heating element are on. So, after a brewing cycle is complete, the reservoir's heating element stays on. Without any in the reservoir to keep it cool, the heating element superheats. So, if water is put in the reservoir while the coffeemaker is on or before the element has adequately cooled, the sudden burst of steam from the water contacting the element can be quite violent.
You can get a faster brew cycle by putting warm water into the reservoir and making coffee right away. But, depending on your hot water supply, the coffee may not taste quite as good.
Jan 10, 2014 | Mr. Coffee JWX27 12-Cup Coffee Maker
just stopped working water will not heat up and drip
Heater element burned out it uses the same element to heat the plate and coffee water. They won't sell this part in fact they use tamper proof torqx screws to keep you away from it. Get a new pot!
Aug 03, 2009 | Mr. Coffee 12-Cup Programmable Coffeemaker
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
1,458 people viewed this tip
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
