Tip & How-To about Xerox Phaser 8550DP Printer
Xerox Phaser errors 09,005.49, 09,006.41, 09,007.42, 09,008.43
Hi.
This procedure will clean errors like Note: type errors 09,005.49, 09,006.41, 09,007.42, 09,008.43 ('Ink Loader Fault - respectively cyan, magenta, yellow, black)
Start disconnecting the power cord for ten minutes , then remove the black stick check it and put it back. Ensure you are using original cartridges.
Turn the printer on, to enter the Service menu:
1. -You can access the menu using the FRONT PANEL:
  • Press the down arrow, select "Troubleshooting" from menu and then press OK
  • Press the down arrow until you get "Maintenance Tools" and then press OK
  • While holding the arrow at the top, also press the down arrow at same time, to access the hidden service menu.
  • Scroll down the menu until getting "Enter Diagnostics" and click OK. Wait about 20 seconds, then go to Step 3
2 - If you can not Access the menu because the printer is stuck with the error message on display.
  • If the printer is on, turn it off and wait 10 seconds. Turn the printer back on.
  • Wait to see the Xerox logo on display.
  • Before Xerox logo getting steady on display, press and hold the Back button (back) and 'i' (Help) on the Control Panel.
  • Hold down both buttons until the display shows "Beginning Initialization Service Mode". Release the button and the printer will restart showing the menu "Service Diagnostics".
3 - Scroll using the arrows until "Function Menu" appears and press OK
4 - Scroll using the arrows until you get the command "Clear Fault ISC" and press OK twice to confirm.
5 - Now push the "back" button on the control panel (usually at the left), then press "Exit Diagnostic", then OK twice to confirm.
6 - The printer will restart, and the error message will be gone.
7 - Remove the sticks, check them and load them back correctly.
If the error does not clear, then it is due to a fault, in which case contact Xerox technical support at the number listed on the owners manual.
Xerox Phaser 8550DP Printer Logo
Xerox Phaser 8860 error 09,005.40:71198
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8@9@6@9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Oct 30, 2014 | Xerox Phaser® 8860/8860MFP Extended...
I am getting the following error. 09,038,46:15008
09,038,46:15008
Ink count flag stuck after melting 2.5 Black Ink Sticks.
Initial Actions
• Check that the Ink Sticks are genuine Xerox.
• Check for obstructions in the Ink Wells.
• Check the Ink Loader data (P/J0150) and power (P/J5) connections.
• Verify the Ink Sticks advance in the Ink Loader.
• If the problem persists, follow the procedure below.
Troubleshooting Procedure
1 Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Are the Ink Sticks loading properly?
Yes) Go to Step 2.
No)Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error. This must be performed following an ink loader replacement.
2 Test the appropriate Ink Melt Heater. Run the Service Diagnostics Ink Melt
[1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
4 = Black
Did the test pass?
Yes) Replace the Printhead
No)Replace the Ink Loader.
Sep 08, 2011 | Xerox Phaser 8560/YN Printer
could tell me what is the following code : 09,035.43:62287 on phaser 8560 mfp. please
Ink count flag stuck after melting 2.5 Cyan Ink Sticks.
Initial Actions
1. Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks. Are the Ink Sticks loading properly?
Yes)Go to Step 2.
No) Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error.
2. Test the appropriate Ink Melt Heater.
[1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
• 4 = Black
Did the test pass?
Yes)Replace the Printhead
Aug 03, 2011 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8500 Error 09,005.40:100473
Hi Carmichael55:
Here is your problem.
9,005.49: Ink loader fault. The cyan ink melt heater is on, but the ink does not appear to be dripping.
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to
Step 2.
Run clearISCfault test to clear the error.
2 1. Manually verify that the ink stick is able to advance in the ink loader chute.
Go to
Step 3.
Remove any blockage and/ or replace the ink stick.Run clearISCfault
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace the printhead.
Replace the ink loader assembly. Run clearISCfault test to clear the error.
Hope this helps
Jul 30, 2009 | Office Equipment & Supplies
Phaser 8560 Error Code 09,005.40.5185
Hi mark711:
Here is you problem.
1 1.
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
Hope this helps
Apr 23, 2009 | Xerox Phaser 8500/DN Printer
3,715 people viewed this tip
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
